Bizhub 600 troubleshooting
C2401
I have a konica minolta, bizhub 750 that is showing an error massage 'c2401. can someone help?
Thread Bizhub 750 error code 2401
Maybe the link above will help. I found it by a google search, and unfortunately I am not familiar with that model.
Apr 22, 2016 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 600 not automatic toner feeding how can resetting
1. Remove the toner bottle then turn on the machine with out bottle inside of it. Let it go though its normal operations then when the machine asks for toner install the bottle.
Dec 18, 2014 | Konica Minolta Bizhub 600 750 Image...
How to reset a password of bizhub 600-750
Which password the admin or the individual passwords Default admin 12345678 or 00000000
Go to:
Admin setting- Security setting -admin password
Oct 23, 2014 | Konica Minolta Bizhub 600 750 Image...
Fault code c2401 on 750 bizhup
Check Erase Lamp, Update firmware if both of earlier didnt resolve the issue change printer control board it defenatly resolve the issue.
Jul 19, 2013 | Konica Minolta Developer 02xk Dv710 for...
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
Bizhub 600 reads wrong paper size in tray 1
Is tray 2 OK?
Any paper stuck behind the draw. Check the setting off draw one in user mode is it for that size paper?
Apr 23, 2013 | Konica Minolta Bizhub 600 750 Image...
I have a konica Minolta bizhub 750 and its giving me error code c2401 what may be the problem
Sir/Mam, The Erase lamp is disconnected. have you had anyone recently replace the drum or developer? if so the erase lamp connection is not seated properly or you do have a bad erase lamp. You will have to remove the drum cartridge open front door life up small pipe unscrew the main nut hold nut unscrew (When screwing back in do not allow the nut to turn to the right) Any way once the cartridge is removed check two connections above the drum to the rear to small connectors (BE CAREFUL DO NOT SCRATCH OR NICK THE DRUM DO NOT EXPOSE TO SUNLIGHT) ensure the two connectors are secured! Re-install. if the code comes back you mite have a bad Erase Lamp. Contact a Technician!
Feb 05, 2013 | Konica Minolta Developer 02xk Dv710 for...
Bizhub 600
Not sure what "sit bian" means??? is it english???
Sep 25, 2012 | Konica Minolta Developer 02xk Dv710 for...
Konicaminolta bizhub 600 machine dropping the toner. what is the solutions?
first toner must must and must be genuine, other wise it wont work in any conditions,
2nd toner density sensors and gamma sensor should be cleaned and all auto setting must be run .
third some time toner drops down the others side of the drum due to recycle clutch did't not work properly and all cleaned toner drops down after filled in recycle area,
Jan 11, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
11 people viewed this question
k24674
jasbo
jasbo
