Question about Dual 03-09 Dodge Ram Quab Cab 2500 3500 02-08 1500 Subwoofer Enclosure Boom Box
2003 ram2500 5.7 hemi wont shift from 2nd to drive or overdrive
1st gear and second gear are fine the trans fluid is good smells good no burnt color or odor heard a pop noise and it just quit working
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
The shift linkage could have come undone or be damaged (hence the pop sound) also could be an electrical fault (fuse making a pop sound when it fails)
Posted on Feb 08, 2014
97 Ford f150 xlt rear wheel drive. transmission not shifting into 3 shifts from 1 to 2 fine when in overdrive shifts in to 3 feels like neutral. Trans need rebuilt or replaced?
Are there any lights lit on the dash ? check engine , overdrive etc..
could be just a shift solenoid ... Try draining trans fluid an replacing filter. Have to drop transmission pan .. what's the fluid look like ? a nice pink color ? does it smell burnt ? Is it full ?
Feb 25, 2015 | Ford Cars & Trucks
2003 ISUZU NPR TRANSMISSION WON'T SHIFT.
Sounds like you need to change transmission fluid and filter. Buy some synthetic AF fluid, cheap or expensive they will all do well, Also change out the transmission filter.
Feb 20, 2015 | 2003 NPR
4L60E Transmission wont shift into 2nd or Overdrive
Check the fluid level. You may want to consider having the transmission flushed. (I recommend BG Products flush system.) Properly flushing the trans removes any varnish the may have built up causing erratic behavior.
Apr 09, 2014 | 1994 Chevrolet C1500
2003 Ford Taurus--about 1 week ago heard noise under hood but car continued to drive okay. Then, I went to go to work, it cranks fine but when I shift into a gear, car does not move. Looked at belt under...
You say transmission fluid levels are good. Is it a nice red or pink color or is it an orange, brown to black color. Does the vehicle actually shift into gear, the linkage from the gear shift from park to drive or reverse maybe be unhooked you can check that out also. Does the trans fluid smell burnt, should be kind of a sweet smell. Good Luck
Jun 28, 2011 | 2003 Ford Taurus
I have a 2001 mitsubishi mirage with 1.8l engine. transmission won't shift out of second gear. Go's in reverse but won't go forward until in second and won't shift out of second gear.
Is this an automatic trans?Does this mean that it just revs in 1st or drive unti it goes into 2nd?Shifts are determined by having sufficient trans fluid in.That the internal valve body is functioning,that external shift solenoids are working,and that the speed sensor on the trans as well as the TPS on the throttle body are working correctly.apart from this they do wear out internal parts and then do these types of things.
Check the transmission fluid level while idling in park with the handbrake on.also if the fluid smells burnt and/or looks dark,it is time for a rebuild.Could you supply some more info,what was the trans like on last drive prior to fault,did it just start up and do this or did it begin while driving?
Mar 26, 2011 | 2001 Mitsubishi Mirage
When I start out 1st gear is fine but when it shifts to 2nd it goes back and forth, if I start in 1st manualy and get enough sopeed and put it in drive it will shift fine, fluid level is correct. 1995...
Sounds like an internal pressure problem, check the oil condition(does it smell burnt and look dark brown ) if so get the transmission pressure checked at a garage and possible overhaul may be needed. Good luck big $ required.
Dec 05, 2010 | 1995 Jeep Grand Cherokee
96 chevy blazer 3rd gear and overdrive slipping
i got a 1996 chev. blazer s-s10 4.3 engine 4x4.problem i got is i got 1st 2nd & overdrive & reverse but no 3rd gear what should i do
Jun 30, 2009 | 1996 Chevrolet Blazer
88 toyota supra auto trans slips. won't up shift to 2nd gear
yep, sounds like your transmissions on its last leg, mabye you can get by, by starting in 2nd, if you have the option lol, but auto tran's are pretty cheap on ebay or try www.supraforums.com seen one for 300$
Apr 02, 2009 | 1988 Toyota Supra
Dual 03-09 Dodge Ram Quab Cab 2500 3500 02-08 1500 Subwoofer Enclosure Boom Box Logo
44 people viewed this question
Top Dual Audio Players & Recorders Experts
Jerry Naidoo
Michial Gueffroy
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
