Keypad on remote wont work :/
I have a E3D42OVX remote, and I can not, I mean for nothing can not get the back keypad of my remote to work. Help?
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Might have damaged. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the sites by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Feb 09, 2014
2 Suggested Answers
gopakumarg43
  • 74377 Answers
SOURCE: remote control RCR312W
Try an other setup code for your remote with your device. Try an other one. Try an other one. In this way, find a code which gives you more functionality. This is the only thing can do in the case of universal remote codes in such cases.
Posted on Jun 17, 2012
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Garage Door Keypad Stopped Working
There is nothing to do beyond what you have done. You need to get a new keypad. Make sure you get the same model as there are some out there that will not work with your opener.
Dec 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster problems with the wireless keypad...
If you reset your code by pressing the smart/learn button and then keying in your code and pressing enter and it still doesn't work it has just quit on you. Make sure if you replace it you get the same model number.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wireless Keypad wont allow use of other door openers
hit learn button for 10 seconds. now nothing will work except wired buttons. Hit learn for 1 second and put in yur 4 digit keypad code and hit enter, light on motor will blink twice. hit learn again for 1 second and push button on remote. again bulb will blink. continue pushing learn for 1 second and adding another remote.
Dec 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keypad instructions
I can probably help.  What is the make/model of your keypad?
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
