Question about Ovens
Kuco 600 stove
Where are the fuses found
Chef Norfolk Deluxe fan forced oven. Oven, lights and separate grill - all lights went out, lost heat and stopped working.
there is a fuse inside the plug,unplug it to check it,please report the other posts
Jun 15, 2015 | Ovens
Does this 25 year old oven have a thermal fuse on the back of the lower oven ?
the older model stoves usually had the line type fuses usually found inside the oven under the top panel? sometimes it is located on the back if u remove the cover plate in back u will see if it has a fuse there
Mar 11, 2015 | Ovens
I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
Apr 05, 2014 | Ovens
What is the single fuse in top panel of electric oven/range for?
Hello there and welcome to fixya
Normally the single fuse that you have found is for the electronics like the clock and the various other basic funtions o the stove ect ect if this fuse has blown out it will limit the stove or the cook top to be able to do such things like setting the timer or turning on the ovens light and it may also effect the troubleshooting program that is built into the stove ok like error codes and simple things like this
Hope this is very helpful for you '
Best regards Mike
May 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Oven not heating up after using self clean oven feature
OK. Not a professional, but I happen to have a lot of experience with this situation. For reference, I have a Whirlpool RBD305PDT11 Double-Oven with a "Self-Clean" feature.
Inevitably, my bride decided that she would "clean" the oven. She set the controls and let it go. At the end of this procedure, I noticed that the electronic control board no longer showed the time or any other lights. So, I checked it out and found that the oven was ENTIRELY non-functional. Virtually nothing would work.
Since this oven is hard-wired, I turned off the fuse and let it sit for few minutes (these things are just computers, so I thought that I would "reboot" the whole thing). This did nothing.
Then, with the help of the internet (thank you, "Fixya"), I found out that this model of Whirlpool oven (and many others of different brand names) seems to have this sort of problem all the time.
It turns out that the physical act of using the "Self-Clean" feature, with its very high heat, blows a few "Thermal Fuses" that are one-use only and cannot be reset. They must be replaced.
First, be sure to turn off the power to the oven BEFORE doing anything. I did this and then took the oven out of the wall enclosure so I could get to the back of the unit. For sake of brevity, I will not go over the procedure to take the oven out of the wall, but those instructions can be found on the internet. Several metal screws hold the sheet metal covering on the top and bottom. Note: This has happened to me twice now (my bride used the "Self Clean" feature without my knowledge) and I have found that the lower Thermal Fuse has NOT blown either time, but the top one has blown both times.
On this unit, the "Oven Shutdown Thermal Fuse" (part number 4451442 costing about $40) is attached with two screws and is located on the upper left section (picture attached below). It is very easy to take the two wire leads off and remove the two screws holding it in place. You can then check this item with a Multimeter to see if the fuse is working. I won't go over the Multimeter instructions, but, you are looking for "Continuity". If you have continuity (electricity will flow), the fuse is good. If you do not have continuity, the fuse is bad.
The first time that this happened (about 5 years ago), the control panel still had lights on and was issuing "error codes" specific to this brand of oven (I don't remember the codes...F1 or something) and the only problem was the fuse as discussed above.
However, the second time that this happened, as I mentioned earlier, the control panel was blank also. So, I had to look for the "Control Panel Thermal Fuse" also. This fuse can be accessed from the FRONT and is behind the control panel. In this unit, that part number is 4451042 and costs about $20. This item is sheathed in clear plastic with a "bullet-looking" thing inside of the plastic. It is very easy to pull this fuse out and check it for continuity to see if it is in working order. Continuity (electricity can flow from one side to the other), and the fuse is good. No continuity, and the fuse is bad. Again, you can check the continuity with a Multimeter. In the second instance of this happening, this fuse was bad also (that is why the control panel had no lights or error codes or anything).
Once I replaced these fuses, the control panel came back, the oven would then respond and worked just fine. If I was to guess, I would say that the cabinet that the oven is installed into is too tight of a space and the temperature just gets way too hot and the fuses blow. This is just a thought, but maybe a fan set to blow at the unit when attempting the cleaning process would help keep the unit somewhat cooler on the outside. But then, at $60 to fix and all of the hassle involved, I am NOT willing try this just to see if it helps!
Just to get in a rant....How a company can sell a unit with a feature of "Self Cleaning" that, when used exactly per the instructions, will render the unit completely useless is WAY beyond me. oven-not-heating-up-after-using-self-m2kgk0sj4irmtvrbwm3x5vdv-1-1.jpg oven-not-heating-up-after-using-self-m2kgk0sj4irmtvrbwm3x5vdv-1-3.jpg
Mar 31, 2011 | Whirlpool GBS277PD Electric Single Oven
Oven does'nt get hot enough,and heat light is not on,found fuse blown for heat, replaced fuse,burn't fuse again?
You need to check inside of the oven where the fuses are in order to see if a cable is disconnected.
The light problem could have to do with the air pressure switch being damaged. You may need to adjust it with a small screwdriver. But first, you need to disconnect the two cables and put them together to see if the light turns on. If that is the problem, you need to then adjust the air pressure swtich. Or if you find that it is damaged, it will have to be replaced.
Feb 24, 2010 | Lincoln Conveyor Oven - 1132-080-A
Hotpoint stove fuse confirguration
Remove the old ones ONLY if you know what you are doing, and take them to the parts place with the modl # and serial # found on the tag plate!
Sep 06, 2008 | Hotpoint Ovens
Whirpool double oven shutdown during self cleaning operation and now is completely dead and the top oven door will not open. I have checked the circuit breaker and it is in the closed position and power is...
Too bad someone didn't answer this sooner. Caused be poor air circulation in the unit. There is indeed a thermal fuse used in this unit. This problem has been around for a while and no real solution has been found. The closest "fix" is to remove the fuse, turn it around and only hook it down with the screw that faces the panel. The other screw hole is then bent to a 45 degree upward slant. This give the fuse a little breathing room.
Dec 17, 2007 | Whirlpool GBD307PDS Electric Double Oven
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
