Question about Car Audio & Video
After market stereo won't power-up in 2002 Pontiac Montana
I have a Pontiac Montana 2002 and I am trying to replace OEM radio/CD unit with an aftermarket compatible one. I connected the speakers, ground and power wires but the new radio does not even power up. What happen? Does it have anything to do with THEFTLOCK feature, or would that simply lock the radio, but will not cut the power. A bit lost.
  • steve_n63630
    steve_n63630 Feb 12, 2014
    The stereo simply does not turn on at all. The old one worked just fine. So if there's a chance there's no power coming in, what might've happen? I checked the fuse and it looks fine. How would I check if there is powere coming through this wire and if not, how would I determin where it's cut off?
  • 21 Answers
SOURCE: problem with factory radio
you probly need a wiring harness....if this is the first aftermarket cd player in the truck... go to car audio place round town and ask for a wiring harness for your model truck....the wires will then be color coded.....hopefully this helps
Posted on Jan 27, 2009
alicantecoli
  • 22156 Answers
SOURCE: replacing radio in 2002 pontiac montana, did not
run a feed direct for the permanent 12v supply and a wire from the ignition switch for the 12v switchable supply .
Posted on May 01, 2010
  • 11 Answers
SOURCE: Stereo wiring on mk4 golf r32? Fitted new stereo
12 volt accessory or same wire that goes to red wire on stereo or cigarette lighter.
OR
What is the current draw on amplified aerial ? or are you talking bout electric aerial(up and down automatically ?) If current draw is really low like 500 milliamp or so then hook her up to blue wire (remote output) on back of stereo but REMEMBER this is LOW current and only meant to switch on amps and raise electric aerials etc.If you think amp on aerial is too much for it then run the rem wire to a 12 volt relay and wire it so that when rem triggers and closes the gate will be connecting an accessory wire OR perm 12v wire to aerial power . That way aerial ONLY turns on(POWERS UP) when stereo is on as opposed to other way where aerial will be powered up every time car ign or acc is turned on regardless of whether the stereo is on or not.
Posted on Jun 18, 2010
nsanedrummer
  • 50 Answers
SOURCE: I switched out my radio
Hello... sorry to hear you are having a problem. The theftlock system does not pertain to anything aftermarket that you do. The theftlock only locks down the factory radio if it is removed, and only if it was activated before it was removed. There was a red led light on the radio. With the vehicle turned off, if the light on the radio flashed, then it was activated. If you hook the factory radio back up then you will have to enter the code to unlock it. Since you used a wire harness adapter, check the red wire and make sure you have 12v current on that line. You didnt state if the radio powers up with no sound or if it doesnt power up at all. If it powers up with no sound, then check to make sure that the blue/white wire is hooked to the blue wire on the adapter harness. Let me know if you are having no sound or no power and I can help you further with this problem.
Posted on Apr 05, 2011
ZJLimited
  • 17970 Answers
SOURCE: Replacing oem car radio/CD (Clarion PN-2165M I)
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Posted on May 25, 2011
I installed a dual Bluetooth stereo system in my 2002 pontiac montana I installed the radio pro 5 I have it all hooked up correctly everything turned on but no sound at all what else could it be?
Depends on the type of OEM radio you had in the system before the replacement. Your car may have an auxiliary amplifier between the radio and the speakers, and if so, you may have to bypass it. In any case, have a look at the original wiring diagram (Alldatadiy.com will probably help) and check your wiring again.
Jul 04, 2017 | 2002 Pontiac Montana
Have 2002 pontiac geand am gt went to replace stereo and now anti theft will not let stereo play how do I fix it
Did you replace it with a factory unit or after market? Did you use a harness adapter if after market?
what exactly is happening?
Nov 12, 2016 | 2002 Pontiac Grand Am
My montana pontiac 2005 is giving me a power error when I try to access the cd player.
Needs repair. You can pull and ship to united radio for repair or have the dealer do it. Other choice is to replace the unit with an aftermarket or salvage unit. Salvage unit may have to be programmed for tou vehicle to work right.
Aug 17, 2016 | Pontiac Cars & Trucks
99 MONTANA RADIO SUDDENLY VOLUMN GETS LOUD HOW DO I MAKE IT STOP
It could be a dirty control. I'd try some electronic contact cleaner. Spray it on the volume control to see if it helps.
It could also be a broken wire that occasionally makes contact with something it's not supposed to.
Apr 13, 2016 | OEM 1999 Pontiac Montana Radio / CD Player...
How do I fix the clock display on my 1999 Pontiac Sunfire?
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Link to oem stereo removal procedures.
Pontiac Sunfire Radio Repair and Removal 2000 2005
Link to aftermarket stereo install / connect procedures. ( Sunfire Video )
HOW TO INSTALL AFTERMARKET STEREO PONTIAC SUNFIRE
Link to aftermarket stereo install / connect procedures. ( General Video )
How To Install Car Stereo Single Double DIN Car Audio 101
Have a nice day.
May 12, 2015 | 1999 Pontiac Sunfire
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
May 25, 2011 | Clarion Car Audio & Video
I bought a used radio for my pontiac montana 2001 but it says the radio is locked how do I unlock it?
There is a security code for it, you may have to get it from the dealer or look it up online if its a factory stereo.
Jun 25, 2009 | 2002 Pontiac Montana
Light burned out on radio/clock dial - how to fix?
Sorry there is no quick fix for this problem. If it's the face plate that light's up, there are some electronic shops that can fix it for under the cost of a new after market radio. Just keep in mind there the junk yard has lot's OEM radio's waiting to be bought.
Mar 24, 2009 | 2003 Pontiac Montana
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
