Oscillating function does not work
The unit is 5 years old, has a few projects of use but kept clean. One day I turned the unit on, the spindle spun but did not oscillate. Investigation with the power off, revealed no clear root cause but if I push down on the spindle and turn the unit back on, the oscillation will begin only momentarily. Lubrication? Springs? Don't know, but might be a simple fix. Does anyone have experience that you'd be willing to offer help?
2 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: Unit power up have sound but no picture.
Check the damper diode and the protection resistor in the High Voltage circuit. Good Luck.
Posted on Jun 19, 2007
How do oscillating drill presses work? I have an old Craftsman 8 inch drill press with spindle sanding capability, but the spindle will not oscillate up and down.
Did you already read your manual for that drill press?if your manual is available there is an instruction on how the drill press work..I think the problem their is the shaft that can be found at the right of the drill press..maybe the error is that the wiring of the shaft.
Jun 11, 2011 | Craftsman Drills
Hello, We have/had a seven-year old unit which was working fine till a few days ago. First, I noticed a pillow-size pool on our basement floor two consecutive days. I moved round the unit since we thought...
It's 7 years old and has severed you well. Repairs on a unit that old, cold cost as much as a new unit. That's, if the parts are still available for a 7 year old dehumidifier.
As far as advice is concerned ... I agree with you. Since you're using it primarily in a basement. Shop for a low temperature unit. That's one that will function well, between 40 & 60 degrees F. I say this, because the ambient air temperature at floor level in a basement, can be 5 to 8 degrees cooler than the air temperature at chest level. Regular dehumidifiers don't function well at the temperatures I referenced above.
The other features you want to look at is energy efficiency and the square footage or cubic footage it's rated to handle. I would suggest, no matter what you buy, if an extended warranty is available ...buy it. It could be money well spent. Then, only the Routine Maintenance is up to you. Which means, don't misplace your owner's Manual.
Hope this helped you. Please let me know.
Jun 07, 2011 | Woods WMD40W Dehumidifier
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
60 grand wega 5 years old picture getting darker
souns like an over heating isue
try cleaning out the unit
take it to the local mechanic have him give your tv a ******* (with compressed air )
heck hes been screwing you so his kids can go to coledge for years whynot get a freebe?
Aug 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Same problem
It sounds like the classic "timer problem" that requires a "kit" (mostly capacitors) to repair it. To have someone do it (such as your service person) for you can be expensive and time consuming. Sets that are 5 or more years old usually have other problems too which, simply put, is a complete cleaning of all mirrors, fans, and filters.
Jun 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS 5047. Won't turn on. When the on switch is pushed it immediately turns itself off.
I had just put in about $500 worth of work into this TV to clean the color tubes of bacteria and other miscellaneous problems - They kept my TV for 3 months before bringing it back. It worked for 2 days and then everything went green, so they came back and took it for another 30 days before bringing it back.
This new problem could have been anything as simple as a tube to a circuitry problem. We decided to junk this Mitsubishi product. I have a 30 year old Curtis Mathis TV that I've never had any problems with (that's 3 times the age of the Mitsubishi).
We've opted for a new 50-inch Panasonic Plasma with the anti burn in technology. I will not buy another Mitsubishi product, or a rear projection TV of any brand after this experience.
Aug 17, 2008 | Televison & Video
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Green screen for 30 seconds, then shuts down
yes you need a new picture tube, those tend to lose there power after a few years.
Mar 27, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Jun 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Televison & Video Logo
Top Televison & Video Experts
