Question about Sta Rite Pool & Spa
Rituo hl 3000
Alerm_oli
Hi I have mazda cx 9 model 2008 having problem oli mixing in radiator water mean coolant bottle gave oli mix please let me know the reason....smoin99@hotmail.com
Your head gasket has a leak & it will need to be repaired at a mechanics with costs starting at around £700.00 Or $1200.00
Nov 11, 2014 | 2008 Mazda Cx 9
Whats 12/22 ?
sounds like the panel is broken. time to replace unit as panel would not be cost effective to replace.
Apr 29, 2014 | Sony PFM-500A2W 42 in. Television
Replace Main Moduke for the Alerm System Light on Dash is on all the time..
You must have the system scanned for the fault that keeping the light on, just replacing parts without proper diagnostics will not cure the problem as you have no doubt discovered.
Jun 27, 2012 | 2006 Toyota Camry
I cant start my 2005 Toyota Solera. I have an aftermarket alerm system in it that I think is causeing the problem. Please Help.
Your alarm system is interfering with the ignition. you need to disconnect and reinstall properly.
Oct 02, 2010 | 2005 Toyota Camry Solara
Antitheft system has the car alarm system activated, when ever i hood up the battery the alerm will never stop blowing the horn and flashing the head ligths.
Hook up the battery, then put your key in the door lock and lock and unlock the door. That should cancel the antitheft. If it doesnt work on the drivers side move to the pass. side door.
Jan 09, 2010 | 2007 Nissan Maxima 3.5 Sl Sedan
No power to fuel pump
if fuses are all good check oli sending unit it has a cut off built in in case oil presure drops so it can be the problem,,, oli sending unit may be leaking or not if it is bad
Jun 30, 2009 | 1999 GMC Savana
1999 BMW 740i The alerm is too sensitive, starts in parking structures, or even on the street.
there should be a sensetivity nob on the alarm box itself turn that down and your problem should be solved if not just invest in a new alarm.
Jul 29, 2008 | 2007 BMW 750Li Sedan
Noisy
I had the same problem with mine. The only solution we could come up with was to place a small towel/washrag underneath it, and wedge it into something if you can. This solved our problem.
Sep 29, 2007 | Wave Industries OLY-OL3000 Globe Phone
Pool & Spa Logo
60 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
