Question about Spirit Exercise & Fitness
Hebb industries treadmill
Incline will not drive down from 15 degrees of incline. Stops by limiter switch.
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
  • 103 Answers
SOURCE: Image 17.0 treadmill is stuck in incline position
Hello there, The first thing I would try is to calibrate the incline on the unit.
Do this using the following procedure.
With the safety key out, press the stop button along with the speed up button while inserting the safety key onto the unit.
remove your fingers from all buttons, Then press the stop button one time. Now press the incline up button one time.
The unit should go all the way to the top, then return to the bottom.
Remove the safety key and reinsert it to continue using the machine
If this does not work you can manually move the machine to the bottom using this procedure.
Remove the hood cover b removing 2 screws in the rear of the machine and removing the first 2 screws on the foot rails on each side.
You can now lift the cover out of the way.
At this point you will see the incline motor located in the center of the unit pointing in a downward direction.
On the top of the motor there will be a small fan encased inside of a metal cover. There will be a flat head screw located inside the metal frame where the fan is. Rotate this clockwise to lower the unit. (the motor is geared very high it may not seem as though it is moving but it is) be patient that procedure does take a little while.
Any questions please feel free to leave another message on this link.
Good Luck! Tim
Posted on Jan 12, 2010
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
maxtreadmill
  • 832 Answers
SOURCE: The incline on my proform treadmill is not working
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Posted on Jul 19, 2010
BH treadmill error 7
You must test the limit switch down in the same place where the Incline motor is there. Of course if there are limit switch. If is coming with capacitor or condenser see for 110VAC up and down, and if NOT voltage the Controller board motor is faulty and replace.
LUBE the shaft of Motor with Grease.
But first test the Incline motor outside for 110vac directly, and see if working. Take your decission using common sense.
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 03, 2017 | Exercise & Fitness
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
Adjust incline on weslo cadence g 5.9 bought it used no manual
On the rear of walking deck you have the left and right feet. Down the deck is at 0 degree incline, fold them up and you have a 3 degree incline.. You have no incline motor on this model.
Mar 02, 2015 | Cadence Weslo 825 Treadmill Walking Belt
What is wrong with and how can I fix the incline on my Nordictrack commercial 1750 treadmill?
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
May 25, 2014 | Nordic Track Commercial 1750 Treadmill...
Not incline or declining
I expect there is a limiter switch that tells the treadmill when it has reached its maximum elevation. The switch is probably either malfunctioning or broke.
Feb 27, 2014 | Nordic Track Exercise & Fitness
Treadmill incline
RUN the software calibration for easy diagnostic, and fix it. Go to THE HOOD cover for the motor and follow the steps or use the owner manual.
God bless you
Sep 30, 2013 | Exercise & Fitness
I have a Powertred 7.0 Softrak treadmill made by Hebb Industries. The LED Readouts for speed, distance and time will only read 000.Pressing the reset key does nothing. Any suggestions on how to fix
adjust the Reed switch see the diagram attached, clean it, and tigh the plug very well.
2) tight the ribbon inside for keypad, and clean it.
3)tight the connector from display board vs lower board.
4) Run finally the software calibration for diagnostic, troubleshooting and fix it.
God bless you
Sep 21, 2012 | Exercise & Fitness
Merit 725T. The treadmill has gone into a "10 degree" incline mode on its own, and will not respond to the control panel to reduce the incline.
Sep 21, 2010 | Horizon Fitness Merit Fitness 725T...
Apr 27, 2009 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
29 people viewed this question
Top Spirit Exercise & Fitness Experts
Mister G
Mister G
Level 1 Expert
Richard Warren
Richard Warren
Treadmill Repair...
Treadmill Repair...
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
