Question about Acer Aspire One D255e 10.1" Lcd Back Cover Ap0f30008b0 "grade B"
Acer aspire one d255 wifi not turning on
Wifi not getting on
SOURCE: Acer Aspire 9410z wifi
i have the drivers for aspire 9410z at this link ( for xp pro )
http://rapidshare.com/files/113659235/xp_driver_for_aspire_9410z.rar
Posted on May 09, 2008
tecnomage201
  • 221 Answers
SOURCE: acer aspire 5735z wifi adapter driver
The drivers can be downloaded from the address below:
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Be sure you get the driver that is for your hardware..
Posted on Aug 07, 2009
eldhobabyk
  • 63 Answers
SOURCE: reset acer aspire one d255
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.This will RESET the computer to its Factory Settings( DATA LOSS )
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Posted on Oct 23, 2010
joecoolvette
  • 5660 Answers
SOURCE: how do you install 2 gb memory in acer aspire one
vtxgreg, I typed out a lengthy solution to replace Ram Memory in an Acer Aspire One D255, but after looking through it once finished, I thought this to be the better solution.
1) Video of how to remove the Keyboard,
http://www.youtube.com/watch?v=FoTwln2SyQ4
[ NOTE*
I advise against using a utility knife blade. That's just Dumb! Use a small flat tipped Jewelers screwdriver.
I also advise buying, and wearing an ESD wrist strap. Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
(You probably won't even see it, or feel it)
Connect the alligator clip to a good ground source.
{I connect to the metal frame of an empty desktop computer case}
Price for an ESD wrist strap averages around $3 to $6.
Here is an example of one,
http://www.newegg.com/Product/Product.aspx?Item=N82E16899339002&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Tools+-+Network+/+PC+Service+/+Acc.-_-Cables+Unlimited-_-99339002
(You can get them cheaper as I stated above)
2) Video of how to replace Ram Memory in an Acer Aspire One,
http://www.djody.com/acer-aspire-one-memory-upgrading/
Use a multi-compartment container for the various screws you will remove.
mark each compartment for the area the screws come out of.
A LOT of the screws look VERY similar to others, but they are NOT.
Do Not mix them up!
If a multi-compartment container is not available, you can use a clean egg carton in a pinch. Mark each egg holder.
Posted on Nov 29, 2010
  • 236 Answers
SOURCE: when i turn on my Acer Aspire One D255 it says:
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Posted on Feb 11, 2011
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
Sir, I have an acer aspire one D255 , how can disassemle this
Hi!
Here is a link where you can get a manual that you can use to disassemble your Acer Aspire One D255-2670. Please click here Acer Aspire One D255-2670.
Hope this can help.
Jul 23, 2011 | Acer Aspire One D255-2670
I want to know if the acer aspire one has only one speaker which is located at the left side? thank you
the Acer Aspire One D255 has stereo speakers, one on each sides. but the Aspire one D255E has only one speaker.
May 01, 2011 | Acer Aspire One D255 Netbook
I had my acer aspire one D255 reformat,after it was reformat when i press functions keys f3 it wasn't displaying the launch manager of wifi and bluetooth...i dont know anymore where and how can i turn on...
Sounds like you need the driver installed for the bluetooth...here is a link to the Acer site with drivers for your model:
http://support.acer-euro.com/drivers/notebook/as_one_D250.html
Just select the bluetooth driver from the first drop-down menu and install it, that should solve your problem.
Hope this helped
Mar 19, 2011 | Acer Aspire One PC Notebook
Wireless network is not responding. How do I get it to work. Also, Windows is not working.
there is a switch on the right hand side below the keyboard to turn on the wifi, as for the " Also, Windows is not working." you will have to clarify the issue to get any help.
Jan 04, 2011 | Acer Aspire One D255-2670
Where can I find a Acer Aspire One D255 AOD255 Replacement Laptop Keys or Keyboard
Here you go, http://www.replacementlaptopkeys.com/servlet/the-16937/Acer-Aspire-One-D255/Detail
They have the acer D255 laptop keys you need, take care.
Jan 03, 2011 | Acer Aspire One D255-2670
I upgraded to win 7 ult. from starter fresh install on a acer d255 netbook and now i cant find the wifi driver
http://downloadnew.org/software/acer-aspire-one-d255-notebook-broadcom-wlan-driver/
scroll towards the bottom of the page...look for your chipset.
Dec 28, 2010 | Computers & Internet
What options do i have to get intrnet connections two networks show up and shows the ssid but it still wont let me
well sir it seems that you are trying to wifi on your laptop via a secure wifi AP .you need a network key or password to get access
Dec 17, 2010 | Acer Aspire One D255-2670
Acer Aspire One D255e 10.1" Lcd Back Cover Ap0f30008b0 "grade B" Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
