Question about Volfenhag Car Audio & Video
Wiring diagram kicker l7 dual ohm - Volfenhag Car Audio & Video
  • 1,602 Answers
  • 113 Answers
SOURCE: kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Posted on Aug 09, 2007
SOURCE: kicker l7
hook them up parellel for 1ohm load
Posted on Nov 24, 2008
  • 11 Answers
SOURCE: i have 2 kicker l7 12 dual voice coil subs.. i
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Posted on Jun 16, 2009
smarthome2
  • 1114 Answers
SOURCE: ONE OHM STABLE 2500W MAX POWER AMP DIAGRAM ON 2
For a 1ohm load it's positive to positive and negative to negative run 1 wire from one speaker to the other. Positive to positive neg to neg. Then 1 wire from the speakers to the amp. The amp will have + - + - on it's inputs for left and right speakers (if stereo) Use the outside positive and outside negative. If there are any switches on the amp that say "mono" "stereo" switch to "mono". Hope this helps
Posted on Jun 20, 2009
rteemon
  • 578 Answers
SOURCE: second opinion on wiring
run seperate
Posted on Jun 26, 2009
How do you wire a single 15 L7
Depends on a few things. What is the impedance of your speaker? I will assume it is dual voice coil with each voice coil having a characteristic impedance of 4 ohms. Next what amp are you driving this speaker with? What is its minimum stable load it can run at in bridged mono? If it is 2 ohms stable then you can wire the voice coils in parallel, + to + and - to -. Then wire the + and - to the amp in its recommended bridged configuration. If the amp is not stable down to two ohms you will have to wire the voice coils in series, you will not have effective power from the amp with an 8 ohm load.
Here is a diagram from kicker to aid you.
http://www.kicker.com/dvc_wiring
Jul 20, 2011 | Kicker Car Audio & Video
How do i wire two kicker l7 dual 2 ohm subs to play on a mtx 7801 class d amplifier
Hello moore_broder,
Your MTX 7801 is stable at 1 ohm, but you cannot wire a pair of DVC 2 ohm subs to that impedance. They can only be wired to 1/2 ohm which is too low or to 2 ohms.
Series the voice coils and parallel the subs. On each sub, jumper Black to Red/White Dot, then run both red's (positive) and both black/white dot's (negative) to your amp terminals.
The diagram is here.
Hope this helps.
Sep 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do you hook up 2 12" L7's to a kicker 1200.1 amp?
You have a 2 ohm stable amp, and dual voice coil subs.. The L7's come in both Dual 4 ohm, and Dual 2 ohm, so you have to know what impedance your coils are prior to wiring. HERE is a nifty little guide that will show you how to wire your subs. DO NOT WIRE THE SUBS LOWER THAN 2 OHMS ON YOUR AMPLIFIER!
Aug 23, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Logic soundlab cpx1400 need to wire to a kicker cvr 15
Hello discrete01,
The Kicker model number 07CVR122 has dual 2 ohm voice coils, and can be wired for either 1 ohm or 4 ohms. Model number 07CVR124 has dual 4 ohm voice coils and can be wired for either 2 ohms or 8 ohms.
Kicker's wiring page is here: http://www.kicker.com/dvc_wiring
If you have the version with 2 ohm voice coils, you want to use the 2nd diagram for a final load of 4 ohms to the amp. The 1 ohm load is too low for the amp and will cause it to overheat and possibly fail. If you have the 4 ohm version, use the wiring shown in the 3rd diagram which is a perfect match for the amp.
Hope this helps.
Aug 11, 2009 | Kicker CVR12 Car Subwoofer
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
Jul 16, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What is the difference in a dual 2 ohm sub and a dual 4 ohm sub?
Dual 2 ohm sub can be wired to achieve a 1 or 4 ohm load.
Dual 4 ohm sub can be wired to achieve a 2 or 8 ohm load.
Usually no difference in Theile Small Parameters.... Only wiring configuration - to get the most power out of your amplifier.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker solo-baric L7
ok here is a real pdf manual from kicker and please rate me
www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf
Jan 21, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
142 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
