Question about 2007 KIA SORENTO Remote keyless entry
Passenger door on drivers side won't lock anymore.
    Sergeant:
  • Kia Expert
  • 403 Answers
Door lock actuator seized inside the door or broken wire in the door does it lock and unlock by hand or key sometimes the rod breaks inside the panel to findout remove inside door panel and check
Posted on Sep 06, 2014
2000 cadillac deville driver side won't open with the key
1) Key turns but dose not unlock door. This means that the rod that goes to the back of the lock has came off. This also means that is the reason door is not unlocking with the remote as it pops the lock rod inside the door which pushes the lock open.
2) Key does not turn lock at all but works passengers side door. This means that the locks has been changed in the door, but that doesn't sound like the problem as you say the remote doesn't open the drivers side door so more than likely the rod has came off the back of the lock
Nov 07, 2012 | Cars & Trucks
1999 Dodge Stratus passenger side door locks won't lock
thier really is no other option.. thier are plastic clips that hold the linkage together.. it's common for those to break.. so the panel has to come off.
Jun 25, 2012 | 1999 Dodge Stratus
Power door lock on chevy equinox does not work on one door how can it be fixed
I had the same problem but on the passenger side door. The wire harness on the passenger side had broken wires. Purple wire was for the lock and thicker blue and darker grey was power for the windows. I used butt connectors to repair and it worked like a charm. Area was tight to work in between vehicle frame and door. Was easier to remove door panel and disconnect harness at vehicle frame and pull harness through door to complete the repair.
Mar 19, 2012 | 2008 Chevrolet Avalanche
First problem started when the passenger door didn't open from outside. Now when you lock the car, the passenger door won't lock.
Sounds like the locking mechanism in the passenger door may need lubrication. You could also have a wiring issue and/or the actuator solenoid on that door could be bad. I'm assuming you are using the keyless locking fob. What happens when you push the door locking button on the driver's side door or the locking button on the passenger door itself? If these work as they should and with not hesitation then you likely have some other problem in the locking system.
Jun 11, 2011 | Volkswagen Golf Cars & Trucks
My drivers side door won't open with a key anymore, passenger side works fine. Janette
It sounds like the door lock rod has become detached from the lock rod actuator. The plastic retainer clip that holds it in place can become dislodged causing them to separate. Fixing this problem is not that difficult but, it does require removal of the inner door panel.
May 14, 2011 | Ford Explorer Sport Cars & Trucks
Drivers side works Passenger side door locks do not work from drivers side anymore.
If all locks work but you can not from master switch. Then your master switch needs to be replaced.
Feb 15, 2010 | 2005 Honda Civic
Power locks don't work with remote or control from
The door lock/unlock input from the driver's key switch goes to the Door Multiplex control unit (main switch), the Door multiplex control unit then sends a signal on the BUS (CAN) circuit to the passenger's multiplex control unit; the passenger's multiplex control unit then controls all the door locks. The passenger's door lock key switch inputs to the passenger's multiplex control unit, if the locks work from the passenger's side key switch but not the driver's side key switch, the most likely cause is the driver's multiplex control unit (main switch) not sending the signal to the passenger's side multiplex control unit. This could also be the drivers side door lock actuator. Hope this helps!
Jan 07, 2010 | 2003 Honda Pilot
Drivers door can not be unlocked from outside the car
Take the driver door panel off and look at the back side of the lock and see if the arm is attached sounds like it might have come off and is not locking the lock device anymore. thanks Jerry holler if you have more.
Feb 06, 2009 | 2001 Hyundai Sonata
2007 KIA SORENTO Remote keyless entry Logo
76 people viewed this question
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
