Question about Radio Communications
I have an icom v8000 and am picking up alot of truck noise/buzzing when receiving transmits
  • Radio Commun... Master
  • 1,654 Answers
Possibly an antenna problem. Check your antenna set up. Be certain all connections are tight, and there is no damage or smashed places in your coax. Also check to see you are using the correct antenna for your frequency bandsplit. Depending on the type of antenna your antenna may need to be trimmed to a specific length. Look at the coil at the base of the antenna (black dixie cup shaped device). Check it for corrosion. Shake it, if it rattles, replace it.
Swap your radio with another vehicle's radio and see if the problem stays with the radio. If so, your radio needs service.
Best regards.
Posted on Feb 11, 2014
  • dustin hansen Feb 13, 2014
    I have since replaced the radio new antenna/coax moved power wires i have grounded my tail pipe/ battery /starter straight to the frame ans if i shut my truck off everything is clear i also replaced the alternator any other tricks or solutions are much appreciated
I have a icom ic-v8000 not transmitting or receving there is no short voltage everything looks perfect. when you key the hand held microphone all you hear is tweet,tweet, tweet......
The IC-V8000 is a high power (75 watts) 2 metre radio, it will draw about 15 amps on transmit. Also you might want to make sure your antenna SWR is low about 1.5:1. If you are not receiving anything at all I suspect you may have an antenna issue and this will also effect your transmit as well as the radio will protect its self by reducing the output to almost nothing if the antenna has a high SWR. If you don't have an antenna analyzer check with another amateur radio operator they may know someone who does. Your local amateur radio club most likely will have someone who help you solving your antenna problem.
Jun 29, 2017 | Icom Radio Communications
My icom v8000 says off when I transmit how do I fix this
Hi
This sounds very much to me like a power supply problem.
If I understand your question correctly, the radio will turn on but when transmitting it shuts itself shuts off. This is usually caused by a poor connection to your battery. Although it is possible to show 12v using a voltmeter, there may not be enough connection when putting the circuit under load. (25 watts is a considerable load)
I would inspect both positive and negative connections (pay particular attention to the crimped lugs) , clean and lubricate them and give it another shot.
Here is a link to Trojan battery explaining in detail the importance of clean battery terminals.
Hope this helps you out.
-Steve
http://www.trojanbattery.com/pdf/WP_BatteryCableGuide_0512.pdf
Mar 09, 2015 | Icom IC-V8000
How to fix icom ic v8000 reversed polarity
you need to change the protection diode
Jun 15, 2014 | Icom IC-V8000
I can transmit to my to my baofeng vr6 but i cant reiceve a transmit from it to my icom v85
Check the input output settings.
the baofeng is notorious for being somewhat difficult to program manually.
Try the software setup if possible.
Jan 16, 2014 | Icom Radio Communications
ICOM 802 NOTRECEIVING
Check the speaker .it may be busted. If you hear any sound your receiver circuit is faulty
Dec 21, 2013 | Icom Radio Communications
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
A buzz accompanies transmission
Hi Richard
This is nearly ALWAYS caused by (A) A poor connection with cabling that is too small or long for the amp draw when transmitting, or (B) Low battery voltage or alternator output.
I'd check the power and ground cables first, and use a cable gauge at LEAST one size bigger.
Oct 24, 2011 | Icom IC-V8000
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
Icom ic720a ham radio not transmitting, pliz help
upon what frequency are you trying to transmit?
Perhaps the radio is blocked from trying to TX on said frequency.
Mar 17, 2009 | ICOM Informatique Radio Communications
Radio Communications Logo
43 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
