Question about Insignia Solutions NS-24E200NA14 24" LED TV 1366x768, 60 Hz, HDTV
Slow changing channels
Why does it take approx 4 - 5 seconds to change channels? I use the remote that came with the tv but to go from one channel to another is too slow.
Same with our Insignia (19" LCD). Takes forever to change channels, and sluggish as heck in general. The viewing angle is poor, and the screen is not adjustable... We have a paperback book under the back part of it's flat base, so we can actually see the picture, without distortion and the shiny, aka "off the optimal viewing angle" silvery look. The picture (when watching it straight-on) and sound is fine, but the slow/sluggish performance, the tiny info and memo text, etc. makes it pain to use. Yes, It was "only" $100 + tax, but it should have a better, more acceptable performance and feature set.
Posted on Jun 20, 2015
TV will not display picture or sound except for 1 station which appears to be 440. I can't change the channel either at the dials or remote. The display says EAS.
DONT USE the remote that came with your TV
use the buttons on the box to change the channel. did the channel change?
usually when someone only has one channel its because they are changing the tv channel not the cable box channel
think of it like this:
the TV is a monitor and should always be on the same channel (3, 4, hdmi, or whatever) its actually the box that tunes and the tv always stays on the same channel.
so if you change the tv channel you are no longer watching the output of the cable box.
USE the remote supplied by your cable provider
Aug 06, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Comcast remote: all of a sudden channel input is slow
Unplug the cable box from the wall socket, wait a few seconds, and then plug it in again. I've heard that this solution works.
Feb 28, 2010 | Televison & Video
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Mar 23, 2009 | Sharp Televison & Video
Channel stuck problem
How long does it take (in seconds) before it changes teh channel? Because some TV's, if you have more than 10 channels, have to wait before they change because you might want to change to a higher channel Example:
suppose your TV has 99 channels but your remote has only buttons from 0 to 9. So if you want to switch to channel 7 the TV waits a little before it actually switch to 7 because there might come another nuber after the 7 as the TV doesnot know what channel you wants. 2 to 3 seconds should be the maximum delay.
If it takes more time, check if this can be changed in the menu, often there is a delay possibility in the setup menu.
If teh delay is over 4 seconds and you still have warranty on it, just return it to the vendor.
Jan 16, 2009 | Samsung 21" FLAT CRT COLOR MONITOR
Remote control
Is this a new condition?
Or has it operated differently in the past?
If you are connected to any kind of box (satellite for example), there is only one channel that the TV sees; usually 3 or 4.
The channel changes are limited to the box.
Aug 22, 2008 | Initial HDTV-322 32 in. LCD Television
Insignia Solutions NS-24E200NA14 24" LED TV 1366x768, 60 Hz, HDTV Logo
136 people viewed this question
Top Insignia Solutions Televison & Video Experts
Tom Chichester
Brian Coughlan
Are you an Insignia Solutions Televison and Video Expert? Answer questions, earn points and help others
