Question about Hoover H120M Front Load Washer / Dryer
Who to fix drain time out on a hoover washer please
After complating the cycal it stop before drain
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
Wascomet w124
Not enough info but i would check and make sure that the timer is the exact replacement or it will do exactly that. Most have plug in modules and some individual wires. If wires, ensure they are in the correct place. Check door latch as well. Have had a lot of issues with them in the past
Jul 02, 2014 | GE WBSR3140DW Top Load Washer
Wascomat w124 schematics
Thereis a possibility that the replacement timer is defective.
Jul 02, 2014 | Washing Machines
Drum not going round at all
can i Have the complate Model Number so i can get you back up and running?
Feb 09, 2014 | Hotpoint WMA54 Front Load Washer
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
HNL 3146 WILL NOT EMPTY AT END OF WASH
Hi davebmail,
It could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
I have winxp sp2 setup farst step complate aftr 39 minit setup runnig and then stop this setup 33minit
you should check your setup Disk. most probably it is spoilt or scratchy. otherwise, a good drive would also guarantee a smooth installation.
Nov 30, 2010 | Sony VAIO PCG-K27 Notebook
Doesn't drain on final rinse cycal, leaves 1" of clean water in bottom of machine.
Make sure your drain hose is attached securely to the underside of counter/sink area. If you have a air/gap, make sure it isn't clogged. Both will cause water to backfill back into the dishwasher especially if you're garbage disposal is clogged or restricted.
Rich
Western Appliance Repair
Appliance Repair Eagle
Oct 09, 2010 | Frigidaire 24 in. GLD2150RCC Built-in...
Hoover H120M Front Load Washer / Dryer Logo
26 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
