Question about Pioneer Televison & Video
Turn off internal speakers pioneer pep4214hd - Pioneer Televison & Video
  • 597 Answers
Your problem should be solved by going into the menu and going to audio section, and turning off internal speakers. I guess you want to connect a surround sound system?
Posted on Feb 09, 2014
Testimonial: "This is not a projection pioneer but a plasma PDP 4214 HD. There doesn't seem to be a way to turn off the internal speakers under sounds or picture. The instructions for the Yamaha sound bar I wish to connect says it will function when the internal speakers are turned off. One solution I found was to place a plug in the headphone jack but there isn't one."
My pioneer receiver powers on but the volume doesn't work. Why is that??
Does this receiver function as only a tuner or does it have speaker outputs? If it has speaker outputs, then there might be switches for turning them on and/or if 5.1 surround sound, sometimes there is a bridge on the back so extra amplification can be added and if that bridge is missing, the tuner signals are sent on to the internal amplifier. On one of mine, that bridge was a 2 wires bent to fit into RCA jacks on the rear of the unit.
Dec 01, 2014 | Pioneer Audio Players & Recorders
Internal speakers
If you go into the menu their should be an option for audio/sound once you enter that sub-menu there should be an option for the speaker internal/external or speaker on/off.
Nov 10, 2013 | Pioneer Elite PRO-940HD Television
Deh-425 and deh-42 no speakers will work
hi ken, problem with your unit could be internal or external. i assume you not an audio technicain, start with checking all your speaker leads and speaker drivers directly, if any of these are found to be faulty try isolating it then retry to see if sound works again. secondly try resetting your unit. if all checks out well then you have an internal problem with your unit. check out your pioneer repair agent in this regard. remember if both units use the same harness(back plug) then chances are that you have an external problem with the speaker wiring or speakers itself. cheers.
Sep 08, 2013 | Pioneer DEH-445
Pioneer vsx82txs turn volume way up and shuts off. phase control flashes,now it won't turn on at all. could powered subs destroy it?
One of your speakers must
be internally shorted. Go into the MMAC menu and turn off one speaker at a time
until you can volume up without having a receiver shut down. DO NOT DISCONNECT
1 SPEAKER AT A TIME OR YOU WILL DESTROY THE AMPLIFIER STAGE OF YOUR RECEIVER!
Mar 26, 2012 | Audio Players & Recorders
I have no sound coming from my rear speakers on my pioneer deh-6300hb
The first thing you will need to do is test all of your speakers and speaker wires for any shorts or grounds. Just one shorted speaker or speaker wire will shut off the audio. If your speakers and speaker wires check out fine, you probably have a bad internal output ic inside of your deck.
Feb 28, 2012 | Pioneer Car Audio & Video
Sound is not working. everything is plugged in right. got the tv from my father-in-law who always had it hooked up to a receiver box. now we have it and dont have a receiver box and are unable to get any...
it sounds like the internal speakers are just off. you should be able to navigate the menu and find where to turn the speakers back on. i have my tv set up with a surround sound system and turned the internal tv speakers off. should be in the sound settings or with a picturre of a speaker.
Dec 24, 2010 | Pioneer PDP-507XD 50 in. Plasma Television
Pioneer indash stereo/cd player DEH-7500MP,no internal amp output
some cars have internal amps for the speakers try connecting the remote wire it's the blue wire with a little white on it worked in my moms van.. if that does not work try testing it with a speaker from your house
Mar 31, 2009 | Pioneer DEH-P7500MP CD Player
I Have a PIONEER PREMIER DEH-9600 MP. THE STEREO TURNS ON BUT THERE IS NO SOUND COMING OUT
Make sure there is no speaker in the system that is grounding to metal...this will cause the internal amplifier in the unit to shut off to protect itself from shorting. you can confirm this by disconnecting all speakers from the unit and one by one connecting them back up until it shuts off again or better yet, using a voltmeter, you can check for a shorted speaker contact or shorted voicecoil.
Aug 10, 2008 | Pioneer Car Audio & Video
I HAVE A PIONNER DEH-P6800MP
If your volume knob does nothing, then odds are your speaker outputs are blown. I would double check the setup menu to see if it has an internal amp shutoff, but I think only Alpines have this..
To access the menu, please do the following:
Press and Hold the "source" button until unit turns off.
Press and hold down the "multi-control" knob until the "language select" display appears.
Rotate the "multi-control" knob until you see something like "internal amp" or aything that looks like it would shut off the speaker outputs.....
Again, i don't think Pioneers have this, so odds are your aplifier chip is blown.
Jul 05, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
Televison & Video Logo
35 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
