Question about Bosch SHU9955UC Built-in Dishwasher
Reinstalling door on bosch integra SHU9955UC? I removed the entire door (was tightening front handle and removed too many screws) and now am struggling getting it back on the hinges. Any suggestions welcome. Thanks.
Cerfer39
  • 709 Answers
SOURCE: Bosch Dishwasher
Hi ED, It sounds like a real problem here. If the springs are still in one piece, my best guess is to to remove the springs from the door. Then attach the springs to the dishwasher body first, then reattach the spring to the door. Not an easy job, good luck. If you have further problems check with www.repairclinic.com, as the repairguru there may be of more help.
Posted on Sep 26, 2007
  • 74 Answers
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
SOURCE: bosch shu 9950
Take off the front panel (10 little screws, two shims will fall out) and you'll see the two handle bolts on the inside of the panel. Tighten 'em; reinstall the panel (good luck figuring out how the shims go back...)
Posted on Jan 13, 2009
SOURCE: Bosch Door Handle: Loose
I had the same problem with my Bosch dishwasher.I came to this web site to find out how to get the door off.I took the experts advice,placed 4 pillows on the floor in fromt,opened the door,took out the screws and the front panel dropped down.It was so easy,the plastic spacers stayed in place.I put a little J B weld on the handle screws and tighted the handle and put everything back together,12 minutes tops.Thanks for the help,thankful in Georgia
Posted on Feb 21, 2009
SOURCE: loose door handle on bosch integra ltd. dishwasher
you can loosen the inside of the door with a small torx screwdriver and lift it up far enough to get to the screw that holds the handle from the inside. I did this with mine about 1 year ago.
Posted on Oct 14, 2009
How do I tighten my Weiser front door handle
Depends on the model. Usually there are 2 screws behind the trim plate that you need to tighten. The handle may need to be removed, to take off the trim plate so you can get at the screws. If that's the case the handle will have a small pin on the shaft someplace. Push the pin in and pull the handle off. Then carefully pry the trim plate off, tighten the screws and reinstall everything.
Feb 09, 2015 | Refrigerators
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Door handle need to be re tightened. Do you hav...
if its just the handle itself it sounds like the fixing clips have come adrift or broken off,the handle strip will need replacing if its the whole console thats loose remove the outer door cover this will give you access to panel screws and may allow you to see more of the handle fitting inside.
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Loose door handle on bosch integra ltd. dishwasher
Aug 30, 2009 | Bosch Integra® 500 SHX46L Built-in...
Hi,I have a Bosch dishwasher SHY 66C02 UC and the handle is loose. What do I need to remove to get access to the front panel? Thanks, Will
u have to remove the torx screws on lhs and rhs of the door and a also at the top of the door.once u remove them the front panel will come out and u can tighten the handle screws.good luck.
Aug 18, 2009 | Bosch Dishwashers
My bosch dishwasher handle is loose
Hi rsouthwick,
I'm Harvey the Master Plumber.
You want to know how to tighten a bosh d/w handle?
Easy! open the door and look around the perimiter. You'll see screws on the right and left, they hold the front panel on. Simply remove them. The front panel is off and you can tighten away!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Jun 09, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch shu 9950
Feb 17, 2008 | Bosch SHU9950 Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
