Question about Kenmore HE2 Plus Front Load Washer
Grinding sound - Kenmore HE2 Plus Front Load Washer
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 15, 2015
Grinding sound
Is the knocking sound when the car is moving or sitting still as well? Does the grinding sound happen just as you put the car into reverse or does it keep grinding?
These transmissions are very problematic, especially if they are not properly maintained. The most likely candidates are a cracked flywheel or a broken drum inside the transmission. Either way, it sounds like the transmission will have to be removed to pinpoint the problem.
Mar 30, 2014 | 2003 Chrysler PT Cruiser
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Auto transmision grinds in reverse, put in dr grinding stops but doesn't move
sounds like it is time to get the transmission rebuilt. usually when they go out you will only have reverse. It sounds like the oil pump has exploded inside the trans. sorry for the bad news
May 27, 2012 | Mazda MPV Cars & Trucks
52 grinding noise from under car . not sure if it
Hi, When a grinding noise is detected first locate the area of the car it is being generated from. Most grinding noises will be being generated while driving, if you are having a hard time detecting the location of the grinding sound, have a helper ride along in the rear seat to give a new perspective on the origin of the grinding noise. A grinding noise can be generated by many things from worn out brake pads to axle bearing failure. Once a grinding sound has been detected action must be prompt. Grinding in most cases is telling you something has failed or is failing. It can be as a result of worn out brake pads or shoes, check your engine and transmission mount, check for axle bearing failure, check your power steering system for leak...
Take care
Jul 23, 2010 | 2002 Jaguar X-Type
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
There's still grinding like sound coming from the rotors.?
Is it a scraping sound or a grinding sound? Double check that everything is good on the brakes and the shields aren't draggin on the rotors.
Apr 07, 2009 | 2005 Chevrolet Impala
Xbox 360 grinding sound
Sounds like a wire hitting one of the fans inside. It could also be the hard drive if you have one. Try to change the way the console is standing and see if the sound gets worse or better to try and narrow down the issue.
Jul 22, 2007 | Microsoft Xbox 360 Console
Kenmore HE2 Plus Front Load Washer Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
