Question about Sewing Machines
I need supreme vikings confratanity orientation
  • Sewing Machines Master
  • 1,388 Answers
Pardon ?
Posted on Apr 22, 2014
I need viking orientation
http://www.husqvarnaviking.com/
Nov 19, 2014 | Sewing Machines
I want supreme vikings confrantanity orientations
Write your answer...iceland our final destination
Apr 22, 2013 | Sewing Machines
Viking Husqvarna #1 + - A bobbin was stuck on the winder and I pulled it off. The black metal clip broke and came flying off. Now the machine thinks it has a bobbin on the winder and won't move the sewing...
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Jul 10, 2009 | Husqvarna Viking 1
Husqvarna viking 770 bobbin sticks on rewind post
I believe that you mean the bobbin is stuck on the winder. If so, take the thread off of it and it will come off easily.
Wind your bobbin at about 1/2 speed until it gets 1/4 to 1/2 full, then you can speed up. Also, make sure that the presser foot is up if winding with thread through the needle. Always make sure that thread feeds smoothly to the bobbin.
The bobbins stick when you have too much tension on the thread or wind too quickly. They will actually squeeze down on the bobbin winder post. Removing thread generally solves the problem.
Jul 06, 2009 | Husqvarna Viking 1
Need Viking Husqvarna Designer 1 ESS Owner's Manual
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a dealer closest to you at the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
Mar 26, 2009 | Husqvarna Viking 1
Bobbin tension on Viking 350 Sewing Machine
Viking bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Mar 19, 2009 | Husqvarna Viking 1
Part for a Viking 6440 Sewing Machine
Check ebay. They sell a lot of parts and/or machines for repair.
Mar 09, 2009 | Husqvarna Viking 1
Husqvarna viking 425
Try ebay or contact your local authorized Husqvarna Viking dealer. You can find a local dealer from the Husqvarna Viking website - http://www.husqvarnaviking.com/us/
Aug 17, 2008 | Husqvarna Viking 1
Sewing Machines Logo
273 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
