Samsung sps 1000
What position should the key be in when down loading from a pc
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
I Have the Samsung SPS 1000 Program Manual in pdf format which shows all key combinations. I will send it to you if you let me know by email. computershack.leo@gmail.com Have a great day.
Posted on Feb 10, 2014
4 Suggested Answers
greg_margo
  • 1959 Answers
SOURCE: sps 1000 - pc connection
The usb port isn't in your cash register. Your cash register has a serial port that should look like this: 70b547a.jpg
You should have a cable that has a USB connector at one end and a port that will accomodate a cable like pictured above.
Posted on Apr 16, 2009
SOURCE: Samsung SPS 1000 set up
http://www.cashregistergroup.com/acatalog/Samsung_sps_1000_pc_software.html
Posted on Apr 22, 2009
  • 400 Answers
SOURCE: Illegible Ascii characters on display
You may restorte defualt settings of your bios..if still then check out if Numlock is off or on and let me inform you that ASCII only recognize (NUMBER) format not Alphabatical format .. if i'm wrong at this you may inform me at my email id of here (azm_zem@hotmail.com)
Posted on Jun 23, 2009
Service Air Bag light on
DTC B0058 Right Front/Passenger Pretensioner Deployment Loop Open.
The passenger seat belt pretensioner deployment loop consists of a seat belt pretensioner-RF and the seat belt pretensioner-RF high and low circuits. A shorting bar used within the seat belt pretensioner connector shorts together both the seat belt pretensioner high and low circuits when the connector is disconnected. This will help to prevent unwanted deployment of the pretensioner during servicing. During a frontal crash of sufficient force the inflatable restraint sensing and diagnostic module (SDM) will allow current to flow through the deployment loop in order to deploy the seat belt pretensioner. The SDM performs continuous diagnostic tests on the deployment loops to check for proper circuit continuity and for shorts to ground or voltage. If a malfunction is detected, a diagnostic trouble code (DTC) will be stored in memory.
DTC B0084 Left Front/Driver Seat Position Sensor Circuit
The inflatable restraint seat position sensor (SPS) is used to determine the proximity of a front driver or passenger seat position with respect to the frontal air bag. The SPS interfaces with the sensing and diagnostic module (SDM). The state of the SPS allows the SDM to disable stage 2 of the frontal air bag for a front seat that is forward of a forward/rearward point in seat track travel. The SPS is a hall effect sensor that is mounted on the inside seat track of both the driver and passenger seats. The seat track includes a metal bracket that shunts the SPS magnetic circuit creating 2 states of seat position. The shunted state represents a rearward seat position. The non-shunted state represents a forward position. The SPS provides 2 current ranges, one range for the shunted state and a second range for a non-shunted state. These 2 states are inputs to the SDM. State 1 (shunted) being the rearward threshold and state 2 (non-shunted) being the forward threshold. When the SDM receives input from a SPS that state 1 threshold is reached (seat is rearward) the SDM will not disable stage 2 deployment, if required by the deployment sensors. When state 2 threshold is reached (seat is forward) the SDM will disable stage 2 deployment on the side the seat is forward. The SDM monitors the SPS circuit and if a fault is detected the SDM will set codes B0083 or B0084 and defaults to disabling stage 2 frontal deployment. This will only default on the side of the vehicle the sensor has a fault. Its important to understand that the SPS is secondary to the passenger presence system (PPS) and the manual instrument panel (I/P) module disable switch. If either one of these devices are in the disable mode the passenger air bag will not deploy regardless of the SPS status.
You should take this to a qualified repair Shop ! Takes special tools to test .
Feb 26, 2016 | 2006 GMC Envoy
Bad value error message
It means the number entered for the task to be performed is wrong. It is easy enough to imagine a numbered menu where you are instructed to choose keys 1 through 5 and you hit a 6 and an error message is generated. You are entering a "value" outside the accepted parameters of the program. Some programs simply do not explain human errors such as entering "B" when we should have answered entered a "2." Such entries are bad "values." Here is an operator's manual and a link to support (which may not be free).
http://cashregisterhelp.com/files/sps2000_op_manual.pdf
SAM4s SPS 2000 Training Videos Table Service Restaurant
How to Reset Samsung Cash Register
Aug 11, 2015 | Samsung Touch Screen Sam4s Sps-2000 Cash...
Which blade on sps-600c speaker is positive and negative.
The wide terminal is the Positive +, and the thin terminal is the Negative -.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 17, 2011 | Alpine SPS-600C Car Component System
Jun 12, 2009 | Microsoft CompuRegister POS-1000 POS...
Sps 1000 - pc connection
Apr 16, 2009 | Microsoft CompuRegister POS-1000 POS...
How can i load the sps game files for visual boy advance?
  • Select File
  • Load SPS file
  • And find the game file you downloaded.
Jan 02, 2009 | Nintendo Game Boy Color Console
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
