Question about Ionic Pro TURBO Air Purifier
Excessive noise After cleaning the filter unit is operating with excessive noise almost a buzzying
  • 6 more comments
  • woodykeith Nov 29, 2007
    Same problem
  • Anonymous Dec 23, 2007
    Same here. It will make an electrical buzzing sound inside, and then say it needs to be cleaned, even though I just cleaned it. :(
  • The Alpha Dec 27, 2007
    Cleaned it and it still sizzles and wheezes. THAT is annoying!!
  • telcoss7 Jan 07, 2008
    Same buzzing noise on 3 units.
  • Anonymous Jan 08, 2008
    excessive noise, also \buzzing after cleaning. we can also see the static electricity sparks, is that normal? cathy, thanks. We have unplugged it, and cleaned it several times, you can tell it is working, the air smells like rain, beautiful. thanks cathy
  • lkohler Feb 06, 2008
    Ditto. What can we do?
  • jchill22 Sep 02, 2008
    It's not just the blades. The 3 (one for each blade) stainless steel electrical contacts, the "tail" of these contacts, and the stainless steel post that touches the tail when you close the unit, all need to be clean, just as the blades do. I cleaned the blades multiple times and still had noise until I cleaned those other items too.
  • Anonymous Jan 15, 2009
    I tried cleaning the thin wire - twice. Still have a buzzing sound. Not as pronounced, but still there
  • 3 Answers
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Posted on Sep 16, 2009
In the ionic pro turbo there is a thin wire in the back that run vertical. Using two fingers try wipping it clean of any dust while using the cleaning rod in combination. Also use purfied distilled water to clean blades. Tap water contain many metals that can cause arching. Be sure the blades are completly dry before turning on the ionic pro turbo. If hissing is still heard use the the cleaning rod twice and check again. If you can see the arch buff the area on the blade with a paper towel or clean newspaper.
Posted on Mar 28, 2008
Brookstone Pure Ion Pro clicking noise, ineffective. I understand the "sparking" is ok, but my unit doesnt "spark". The fans run, and the unit makes two different clicking noises; ...
did you ever figure out the clicking noise problem?
mine stared doing the same darn thing after I whashed the filters and inserted them into the units, I used the builted in drying setting, and thats when the problem started. I know you are not supposed to run the unit with a wet filter, thats why I put it on the dry mode first. I think I am just going to return them back to Brookstone.
Jul 08, 2012 | Air Purifiers
Help!
Try leaving it unplugged for a while to reset it.
Jul 23, 2008 | Brookstone Pure-Ion (506840) Air Purifier
How do I fix the noise?
let it dry completely, disassemble as you would for cleaning, and remove filter unit. Inspect to make sure no paper or other debris like a seal has been dislodged. If you can see fan blade, see if it will turn with filter removed. If it moves easily, reassemble carefully and make sure the contacts are oriented correctly and any charcoal filter is on place as well. Try unit.
If noise persists, the unit has to be opened up to inspect bearings of fan/motor and to locate and remove any debris. At that time a drop of light sewing machine oil or pellet gun oil to lubricate the bearings is a good idea.
Jan 23, 2012 | Air Purifiers
CLEANED FILTER. PUT THE FILTER BACK IN AND NOW IT IS MAKING A CLICKING NOISE. TOOK THE VACUM TO THE FILTER AND IT IS STILL MAKING THE NOISE
The clicking noise is the sound of the high ionizing voltage 'shorting' due to dirt or humidity or both which provides the pathway for discharge. Cleaning and completely drying the filter(s) does not always help, in this case switching the unit to a lower operational speed can mitigate this problem. New filter(s) may be needed to resolve the clicking.
Sep 13, 2010 | Honeywell QuietClean HFD-110 Air Purifier
When clean the filter in one hour the machine stop and i need clean back
clean the metal filter grid blades with a long strip of scotch brite pad and also clean the corona wires in the back of the unit very gently with light grade sandpaper. i had this problem and tried cleaning my unit so many times that i was ready to toss it into the trash. now it works normally. i did some spray painting in the room where the unit was operating and believe it picked up a coating of paint causing the sparking. good luck!
Jul 22, 2010 | Sharper Image Hybrid GP (SI724) Air...
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Unit 8 mos. old and now makes loud, awful noise
you have had the thing for 8 mos try cleaning the hepa filter with a vacuum use the brush type attchment or u might have defective filters go to kaz.com or contact honeywell
Jun 24, 2008 | Honeywell HHT-081 Air Purifier
Ionic Pro TURBO Air Purifier Logo
1,333 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
