Question about Yamaha Televison & Video
How to open rav211
Take 1 schrew out and i can not open int
Where is the location to replace overhead lights fuse in 2003 oldsmobile aurora
Rear fuse box. INT LP 10 amp . there is also INT LP relay in the same rear fuse box .
Fuse Block - Rear
Under the rear seat, on the left side of the floor pan
The INT LP fuse in the fuse block - rear supplies battery positive voltage to the normally open switch contacts of the INT LP relay. The INT LP fuse also supplies battery positive voltage to the INT LP relay control circuit. The fuse block - rear also supplies battery positive voltage to the relay control circuit for the front courtesy lamp. The door modules communicate on a simple bus interface (SBI). When you open any door, the switch contacts of the door open switch close. When a door open signal circuit is grounded, that door module sends a message to the drivers door module (DDM) in order to indicate that a door is open. The DDM sends a class 2 message to the rear integration module (RIM) in order to indicate which door is open. The RIM activates the INT LP relay in order to provide battery positive voltage to the interior courtesy lamps. When any front door is opened, the RIM will energize the FRT CTSY lamp relay grounding the I/Pcourtsey lamps at G302. Depending on which doors are opened, front or rear, the proper interior courtesy lamps illuminate. The RIM provides a pulse width modulated ground to all interior courtesy lamps for the interior lights theater dimming feature. Some of the courtesy lamps are also used as reading lamps, each reading lamp may be manually turned on or off using it's own respective switch
Sep 24, 2015 | Oldsmobile Cars & Trucks
I have a surface tablet unable to connect to wi fi
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
Jun 30, 2014 | HP Compaq nc6000 Notebook
PROBLEM WITH DRIVER
1. Open command prompt with administrator credentials (Find CMD and right-click - Run as Administrator).
2. Enter netsh environment. Type "netsh" and ENTER.
3. "int teredo" and ENTER
4. "set state disabled" and ENTER.
5. Open Device Manager and uninstall "Teredo Tunneling Pseudo-Interface".
6. Open command prompt with administrator credentials once again.
7. netsh + ENTER.
8. "int ipv6" + ENTER
9. "set teredo client" + ENTER
10. Open Device Manager and Scan for new hardware.
11. Select "Show hidden devices" from the View menu. You will now see that it is present without errors with any luck.
hope this helps
Aug 10, 2012 | Microsoft Computers & Internet
Hello... i need a program in c...... a calendar where you can save on a specific date a reminder...
#include <stdio.h>
#include <conio.h>
#include <math.h>
#include <iostream.h>
#include <fstream.h>
int getdaycode(int year)
return(year+(year-1)/4-(year-1)/100+(year-1)/400)%7;
int bool getleapcode(int year)
return year%4==0&&year%100!=0''year%400==0;
main()
clrscr();
int choice,month,days,day,daycode;
printf("\t\t\tSCHEDULER-CALENDAR PROGRAM\n\n\n");
printf("Please choosefrom the Menu:\n");
printf("\t1- Calendar Dislplay\n");
printf("\t2- Schedule Editor\n");
printf("\nChoice: ");
scanf("%d",&choice);
if(choice==1)
clrscr();
int year;
printf("\tCalendar Display\n\n");
printf("Type the YEAR to be Displayed: ");
scanf("%d",&year);
printf("\nYear = %d",year);
bool leapcode;
daycode=getdaycode(year);
leapcode=getleapcode(year);
for(month=1;month<=12;month++)
switch(month)
case 1:
printf("\nJanuary");
days=31;
break;
case 2:
printf("\n\nFebruary");
if(leapcode)
days=29;
else
days=28;
break;
case 3:
printf("\n\nMarch");
days=31;
break;
case 4:
printf("\n\nApril");
days=30;
break;
case 5:
printf("\n\nMay");
days=31;
break;
case 6:
printf("\n\nJune");
days=30;
break;
case 7:
printf("\n\nJuly");
days=31;
break;
case 8:
printf("\n\nAugust");
days=30;
break;
case 9:
printf("\n\nSeptember");
days=31;
break;
case 10:
printf("\n\nOctober");
days=30;
break;
case 11:
printf("\n\nNovember");
days=31;
break;
case 12:
printf("\n\nDecember");
days=30;
break;
printf("\n\nSun Mon Tue Wed Thu Fri Sat\n");
for(day=1;day<=daycode*5;day++)
printf(" ");
for(day=1;day<=days;day++)
printf(" %d ",day);
if((day+daycode)%7>0)
printf(" ");
daycode=(daycode+days)%7;
if(choice==2)
printf("Schedule Editor\n\n");
FILE *fptr1;
char filename1[]="sched.txt";
int reval=SUCCESS;
if((fptr1==fopen(filename1,"w"))
printf("File cannot be opened\n");
reval=FAIL;
else
CharReadWrite(fptr1);
fclose(fptr1);
int
getch();
return 0;
Sep 07, 2011 | Computers & Internet
Source code for implementation of linked list using opengl in vc++
Source code:
#include
using namespace std;
class linklist
private:
struct node
int data;
node *link;
}*p;
public:
linklist();
void append( int num );
void add_as_first( int num );
void addafter( int c, int num );
void del( int num );
void display();
int count();
~linklist();
linklist::linklist()
p=NULL;
void linklist::append(int num)
node *q,*t;
if( p == NULL )
p = new node;
p->data = num;
p->link = NULL;
else
q = p;
while( q->link != NULL )
q = q->link;
t = new node;
t->data = num;
t->link = NULL;
q->link = t;
void linklist::add_as_first(int num)
node *q;
q = new node;
q->data = num;
q->link = p;
p = q;
void linklist::addafter( int c, int num)
node *q,*t;
int i;
for(i=0,q=p;i {
q = q->link;
if( q == NULL )
cout return;
t = new node;
t->data = num;
t->link = q->link;
q->link = t;
void linklist::del( int num )
node *q,*r;
q = p;
if( q->data == num )
p = q->link;
delete q;
return;
r = q;
while( q!=NULL )
r->link = q->link;
delete q;
return;
r = q;
q = q->link;
cout}
void linklist::display()
node *q;
cout for( q = p ; q != NULL ; q = q->link )
coutdata;
int linklist::count()
node *q;
int c=0;
for( q=p ; q != NULL ; q = q->link )
c++;
return c;
linklist::~linklist()
node *q;
if( p == NULL )
return;
while( p != NULL )
q = p->link;
delete p;
p = q;
int main()
linklist ll;
cout ll.append(12);
ll.append(13);
ll.append(23);
ll.append(43);
ll.append(44);
ll.append(50);
ll.add_as_first(2);
ll.add_as_first(1);
ll.addafter(3,333);
ll.addafter(6,666);
ll.display();
cout ll.del(333);
ll.del(12);
ll.del(98);
cout return 0;
May 19, 2011 | Computers & Internet
I have problem in how to call the matrix using fuction
I don think u are in the right way to program the Matrix in C language, i found a lot of syntax error in your code, but nevermind i had correct it for u. Maybe still need a little correction for your own. Following code:
void matrix(int a[2][2],int b[2][2],int c[2][2]);
main()
int a[2][2]={{3,3},{4,4}};
int b[2][2]={{1,1},{2,2}};
int c[2][2]={0},i,j;
matrix(a,b,c);
printf("product of 2 matrix is");
for(i=0;i<2;i++)
for(j=0;j<2;j++)
printf(" %d",c[i][j]);
printf(" ");
int row,col,sum1=0,sum2=0;
for(col=0;col<2;col++)
row=0;
sum1=(a[row][col]*b[row][col])+(a[row][col]*b[row+1][col]);
c[row][col]=sum1;
sum2=(a[row+1][col]*b[row][col])+(a[row+1][col]*b[row+1][col]);
c[row+1][col]=sum2;
Sep 10, 2009 | Intel Computers & Internet
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
Java source code
* To change this template, choose Tools | Templates
* and open the template in the editor.
//package optimalcluster;
* @author CSEEXAM2008
import java.awt.*;
import java.awt.geom.*;
import javax.swing.*;
public class GraphingData extends JPanel {
double[] data = {
0.504782921308152, 1.174144134378306, 2.0933754535558546,6.2625807939548823,8.8484441414277364,10.0000003,12.908978000,14.8906789456,12.9087654567 };
final int PAD = 20;
@Override
protected void paintComponent(Graphics g) {
super.paintComponent(g);
Graphics2D g2 = (Graphics2D)g;
g2.setRenderingHint(RenderingHints.KEY_ANTIALIASING,RenderingHints.VALUE_ANTIALIAS_ON);
int w = getWidth();
int h = getHeight();
// Draw ordinate.
g2.draw(new Line2D.Double(PAD, PAD, PAD, h-PAD));
// Draw abcissa.
g2.draw(new Line2D.Double(PAD, h-PAD, w-PAD, h-PAD));
double xInc = (double)(w - 2*PAD)/(data.length-1);
double scale = (double)(h - 2*PAD)/getMax();
// Mark data points.
g2.setPaint(Color.red);
for(int i = 0; i < data.length; i++) {
double x = PAD + i*xInc;
double y = h - PAD - scale*data[i];
g2.fill(new Ellipse2D.Double(x-2, y-2, 4, 4));
g2.setPaint(Color.black);
g2.fill(new Ellipse2D.Double(x-2+4, y-2+4, 4, 4));
g2.setPaint(Color.blue);
g2.fill(new Ellipse2D.Double(x-2+6, y-2+6, 4, 4));
g2.setPaint(Color.pink);
g2.fill(new Ellipse2D.Double(x-2+8, y-2+8, 4, 4));
private double getMax() {
double max = -Integer.MAX_VALUE;
if(data[i] > max)
max = data[i];
return max;
public static void main(String[] args) {
JFrame f = new JFrame();
f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
f.add(new GraphingData());
f.setSize(400,400);
f.setLocation(200,200);
f.setVisible(true);
Feb 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
C PROGRAM
#include <stdio.h>
int main ()
FILE * pFile;
int c;
int n = 0;
pFile=fopen ("test.txt","r");
if (pFile==NULL) perror ("Error opening file");
else
do { //DO
c = fgetc (pFile);
if (c == '$') n++;
} //DO
while (c != EOF);
fclose (pFile);
printf ("File contains %d$.\n",n);
return 0;
Aug 31, 2008 | Computers & Internet
Televison & Video Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
