Question about Bushnell Optics
Bushnell fov 300
Digital cam not working
Is there a factory reset
Normally you have to send it in to Bushnell and have them do it for a fee but in the past I used the following to reset a similar Bushnell trail cam and it may work for you:
1. Turn camera on and wait for the password screen.
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail Sentry cams will not indicate a 5 digit mode on the screen, but it will show "-----".
3.Press enter to confirm 5 digit mode.
4. Enter the 5 digit code "66214, then press enter. *Note it will accept a 5th digit.*
5.Camera should display "PASS" and go into the operating mode.
From here you can program a new password from the setup mode.
Nov 08, 2014 | Bushnell Trail Sentry 11-9200 Digital...
I HAVE A CANON EOS REBEL T2 35MM FILM CAMERA AND AM PURCHASING A CANON TI1. CAN I USE THE SAME LENS ON BOTH CAMERAS?
Yes, you should be able to use them. Be aware, moving to digital there is a 1.6 crop factor. The means your 100 mm lens will have the field of view (FOV) of a 160 mm. No, it does not mean it is a 160 mm it is the fFOV is the same as a 160 mm. Also, at the other end is were you will most want to purchase a wide angle lens.
Example: your 28 mm film lens now has the FOV of 44.8, not wide angle. As you can see wide angle is where the move to digital crop sensor cameras lose out. To get back to wide angel you would need a 17 mm lens, that would give you 27.2 mm FOV.
To figure FOV take the lens multiply it by the crop factor. On a Canon it is 1.6, on a Nikon it is 1.5, the 4/3 sensor is 2.0.
Nov 01, 2010 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
How do you get around the small field of view
You can't. This is a toy, not a real scope. The largest FOV is with your lowest power (biggest number) eyepiece.
If interested in wide field views, buy a GOOD telescope with a low focal ratio (below f/8)
Oct 10, 2010 | Bushnell Tasco Telescope Galaxsee 525x60mm...
Need manual for bushnell 1025 fov 300
Download it from http://bushnell.com/manuals/binoculars/11-1025_imageview.pdf
Aug 17, 2010 | Bushnell ImageView 111025 Binocular
Wont take pictures
If every thing is working on the cam but the camera, and your cam has a built in memory, take the memory card out. Try using cam with just built in memory. Sometimes the cam wont format right with the memory card. Don't know why, but it just happens. If this works, you'll have to get another memory card. If the cam doesn't read the memory card, it will still work, but it won't take pictures.
Aug 30, 2009 | Bushnell Trail Scout 11-9500c Digital...
PC Cam 300 and PC Cam 600
Probably the driver isn't installed properly. Try updating the driver for PC-CAM 300 and PC-CAM 600.
Sep 12, 2005 | Creative Labs PC-Cam 600 Digital Camera
Sep 12, 2005 | Creative Labs PC-Cam 300 Digital Camera
Optics Logo
26 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
