Question about Gateway GT5654 Desktop PC
Motherboard wiring - Gateway GT5654 Desktop PC
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
Correct front panel wire connector to the motherboard pins
Please refer to the link that i provided to you for the detailed information of your motherboard. Please click here.
May 31, 2010 | ASUS P5PE-VM Motherboard
Connection of inbuolt speakers on motherboard..
Dear User,
Pl Take Your Motherboard Make and model no with its diagram.
(1) Diagram contains inbuilt speaker pin where to connect wire.
(2) Anoter way please see on your motherboard small pin when wire hang. Read Carefully around pin in small latters for speakers pin.
Feb 26, 2010 | MSI K9MM-V Motherboard
Cannot connect usb on motherboard??? URGENT HELP
Have you searched the net for motherboard wiring diagram ... plenty available ... I recently downloaded one. There is only four wires to connect + , - , D+ and D- . Hope this helps.
May 12, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
How to put all the wiring from box onto the motherboard
can you tell me whitch kind of model from msi you have?
so i can tell you a link to take his manual and wired up your wires.
Apr 08, 2009 | Intel Motherboard
Wiring hookup instructions for ecs 945 gct -m mATX motherboard
Hi joe, if you're question refers to ECS 945GCT-M motherboard, than goto page 12 in the manual. You'll see this
77d37bb.jpg Please read all of pg.12.
It's my guess you bought this board from powerspec. For now forget the two red wires & just hook up the case's wires for all LED's & on/off. Everything should be just fine.
Good Luck!
Mike
Jul 02, 2008 | Intel Motherboard
HDD,power led connections
see on the motherboard, there will be athor wire connected from the cabinet.
Read care-fully you can find, HDLED, SPKR, PWS, RSET written on motherboard. and also on the wires you can find like this.
So connect HDD Led wire to HDLED position on the board.
If any problem just Ask me
Thanks
Iqbal
Apr 06, 2008 | Shuttle AV42 Motherboard
Intel D101GGC Motherboard front headphone mic not working becoze wire not attach in motherboard
Simple dear connect the wire on Motherboard. The pins you will get near the outer portion of your motherboard.
Feb 24, 2008 | Intel D101GGC Motherboard
MOTHERBOARD WIRING
Instructions should be in the manual found here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=302
They sound like they are for your from usb posts on case...but thats just a gues :)
Hope that sorts it for you?
Dec 30, 2007 | MSI 645 Ultra333 Motherboard
Gateway GT5654 Desktop PC Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
