Question about Snuggle LLC SnuggleStrap Fleece Strap Covers for CPAP/BiPAP Masks & Headgear 1-Pair
Is there a padded cover available for a back neck strap for a bi pap
Apnea alarm begins to sound during the test. i need to desactivate the alarm
This is not something that you can do. The settings are only accessable by the clinic that issued you the machine.
Apr 09, 2014 | Respironics OMNILAB ADVANCE Bi-level PAP
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
How do I replace the Fuel Pump?
The fuel pump is located in your fuel tank...you have to drop your fuel tank to replace it...before you do so you will have to sifion [sp] most of the gas out as gas is heavy...when you get out all you can leave the gas cap off and remove the bolts holding the filler neck in place...Then jack up vehicle and place on jack stands....Remove battery ground cable,go under and remove sheild covering fuel tank,while there remove the ground strap attached to the filler neck...Once the cover is off this will expose the 2 tank holding straps.....at this point you will need a jack or holding and lowering devise to support the gas tank..... make sure it is supported well before you loosen the strap bolts!!!! disconnect the EVap hose from canister it runs to tank then remove the strap bolts ...move them aside and lower the tank enough to expose the top where the fuel lines are disconnect them and the electrical connector,ground ...then lower gas tank slowly checking nothing is still hooked to it ...After the tank is down remove it from under vehicle and use a BRASS punch or piece of wood not a regular metal punch to remove the pump retaining ring ...once ring is removed CAREFULLY remove the pump from the tank.....replace pump and new strainer... Then Carefully put the pump back in the tank...if needed replace the ring seal before you place the pump back in...tighten up the retaining ring ....take back to car and put on supporting devise and lift just high enough to reattach all your connectors...then jack up the rest off the way attach holdings straps ,cover,ground ******** filler neck,filler neck bolts,battery cable install gas cap and start hopfully
Nov 09, 2010 | 2001 Chevrolet Impala
I need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Jan 24, 2010 | Eddie Bauer 3-In-1 with Latch
Need to know how to replace fuel pump on 2002 Pontiac Grand Prix 3.8 v6
You don't need to drop the tank to replace the fuel pump.
Under the carpet in the trunk there is a access cover that you can take off to access the pump. You need a good snap ring pliers to get the snap ring off to release the pump from the tank.
I wish people would have first hand knowledge of the process before they start clicking post and cost a person a lot of money and time for something that isn't needed to be done to complete the job.
Oct 10, 2009 | Pontiac Grand Prix Cars & Trucks
Camera was dropped with lense out
These cameras are much too fragile to survive a drop, using the wrist strap is an absolute necessity.
Aug 18, 2008 | Cameras
Straps back on after washing
turn the metal clip sideways to slide it through the cover and then through the back of the chair. Get the owner's manual and instructions online if you need more help at www.evenflo.com
May 27, 2008 | Evenflo Chase Comfort Touch
Nania Nuevo 3-in 1
hi,
i just had the same problem but there seems nothing out there at all, so i had to try myself and just succeeded there.
so a little step by step guide, i hope its clear enough.
1. i found taking the whole thing apart to be the easiest way. so take it apart, you should have two long straps, two metal buckles, and two plastics things you will need at the end.
2. hang the strap with the shoulder pads around your neck, the way it would lie if around your child.
3. note two whole, one on either side of the seat, inside, near where your childs bum would be. imagine the other strap, the long one coming from there(imagine we are starting form the right here), then it goes through the right buckle.
4. next it goes through the right shoulder pad
5. now in real life it would go thorugh the back of the seat, but its easier to leave this last, in case you pull it through lopsided somewhere, so you can fix it, anyhow....
6. the long strap now goes around your neck and through the other , the left, shoulder pad,
7, then it goes through the left hand buckle
8. lastly, it WOULD go through the hole on the inside left of the seat.
before you do that thought, close the buckle and see if everything is straight
9. now pick one end of your work and pull it through one of the holes in the back of the seat, once its thorugh one hole it should go through a thinner grey strap at the back, this is for tightening the whole thing at the fornt once your child sits in the seat, once thats done pull it back out front through the other hole.
10. lastly, pull the long ends of the straps through the two inside holes either side of the seat, they should come out at the bottom, the two plastic green things are then attached to the ends. there is a right and a wrong way here, one way you can pull them in tight, the other you cant
i hope this works for you and i hope i made sense....
Antje
Mar 22, 2008 | Nania Nuevo 3-in1
Snuggle LLC SnuggleStrap Fleece Strap Covers for CPAP/BiPAP Masks & Headgear 1-Pair Logo
322 people viewed this question
Top Snuggle LLC Medical Experts
Electro Med Services...
masud
masud
Are you a Snuggle LLC Medical Expert? Answer questions, earn points and help others
