Question about ASUS A8N-E Motherboard
Computer powers off during boot
Installed new ASUS A8N-E mobo last week and it powered on and worked great!
Now the computer will shut down about 1 second into boot! All lights go out!
I have reset the processor, checked the cooler paste and reset the cooling fan. All fans power on when start button is pushed. Reset the memory (1gig) in the blue sockets. Reset the video (ASUS) card. Checked all electrical connections and plugs at fans, hard drive, CDROM's and neon transformer. All were unplugged and reset.
If I keep pushing the power on button for numerous times, kinda keeping the power to the system, it may start up. Sometimes if it does start, it may "click" and shut down anyway. Then I have to start over again.
Boy, any help on this one would really be appreciated!
DJ
It seems to be the hard drive! Unplugged it and the system boots! Plug in the hard drive and it won't start!???
Just my luck!
Posted on Oct 28, 2007
  • 24 Answers
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
I have everything installed in a case,but when I turn on the power,I get a blank screen.I have no os installed,this is just initial startup.What could be the problem?
With all installed you need to tap delete or f8 during boot to set up BIOS for the display type and other devices, also connect the mobo speaker so you can hear any possible error beep codes before it smokes...
Sep 02, 2009 | ASUS A8N-E Motherboard
A8N-SLI Deluxe asus motherboard wont boot
first you want to make sure
the power supply works, they can stay on for a week then die, then work again , then die
then disconnect the cd rom, and see if it still has the same problem,
next could be the processor , this would be the cheapest part next in line,
processors get warm when they work
if not , you would replace that before motherboard
you can also disconnect the hard drive a while
to make sure there are no config errors
Jul 21, 2009 | ASUS A8N-SLI Deluxe Motherboard
Bootup
a bad power supply or a hairline crack in the mobo
Jun 04, 2009 | ASUS (P4BGV-MX) Motherboard
Asus A8N-VM CSM wont boot, no fans come on or anything, green light comes on the motherboard, is the CPU dead? tried different ram still the same. any help would be great!
CHECK ALL JUMPER ON THE BOARD AND MAKE SURE THE BOIS RESET JUMPER IS ON JUMPER 1-2, SOUND LIKE A POWER SUPPLY PROBLEM NOT ENOUGH WATT TO RUN THE SYSTEM
2ND OPTION, REMOVE ALL WIRE AND ADDTIONAL CARDS, MIN. MEMORY, LEAVING 1 STICK OF RAM, VEDOI CONNECTION , AND THE POWER TO THE BOARD, CONNECT ONE WIRE AT A TIME AND RESTARTING THE MACHINE EVERY TIME UNTIL YOU FIND THE PROBLEM.
CANDYMANGANDY
Feb 05, 2009 | ASUS A8N-VM CSM (00610839133826)...
Asus A8N-E failing? Chip fan dead?
The CPU fan need to be replaced and the CPU may now be damaged for overheat.
Jan 19, 2009 | ASUS A8N-E Motherboard
Troubleshooting no screen output, please help
sounds like your system is not booting, that may be, obiusly you just have power but that's it...no boot routine. hope somebody else could help on "how to make sure your system can boot again, then the rest.
Dec 23, 2008 | ASUS A8N-SLI Motherboard
No Video
Try another power supply. I believe you would have this problem if your 4-pin connector from the power supply is not connected to the board. Of cause, you might have a defective board.
May 22, 2008 | ASUS A8N-E Motherboard
Asus a8n sli deluxe not powering up
do you have 2 sticks of ram in the pc?
if so try it with one in and do this with both
as in boot it with a single ram stick and try to determine if its a faulty ram stick
also if you can try another power sup unit
please let me know how you get on
Mar 22, 2008 | ASUS A8N-SLI Motherboard
Asus A8N-SLI Deluxe Problems Booting
Sounds like the power supply is overloaded. Is this a new configuration? Start removing components until it powers up. If it still doesn't power up, check to ensure you don't have a short in any of the connectors that you installed components into. Sometimes when a video card, memory DIMM, or whatever, gets installed, there is a chance that a connector pin will get crushed and short out to nearby pins. If none of those work, you might want to try a larger wattage power supply. Good luck.
Nov 24, 2006 | ASUS A8N-SLI Motherboard
ASUS A8N-E Motherboard Logo
185 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
