Question about TDK Life On Record Wireless Weatherproof Speaker
Battery charger connector is broken for TDK Life on Record A33
Need to know if can be repair
Msi charger
it's either computer connector problem, or charger connector cable problem, or broken cable, or broken charger, or loosen connection between wall cable and charger, or charger to wall cable, or battery problem.....
if it runs, but not charging, I assume it can be battery issue...
Feb 15, 2014 | Computers & Internet
Battery life short if not on ac adapter
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 12, 2013 | Toshiba Satellite Computers & Internet
Have 2 lights on charger. One power, the other says charging. Both come on but after about 15 mins the charging light goes off. Does this mean the battery is charged?
so no lights go green, it depends on the charger however in my experience all of the charger i have repaired have a green light to show fully charge, is it possible to try another charger ? this could imply a faultly charger , can you check the battery voltage anywhere from 26 volts DC to 28.3 volts DC no more otherwise you shorten the life of the battery. You really want the voltage level to be near 28 volts that way you will get maximum distance as well as prolonged life of the batteries in question.
Regards
Please leave feedback.
Dec 19, 2012 | Pride Mobility Products Go-Go Elite...
My eee pc 1005hab was dropped on the floor breaking the charger while still in the port, i took the charger out, netbook still on and used it till the battery died. that was two weeks ago. i now have a new...
I am afraid that I have bad news. You have more than likely broken the connector in your computer. Unless you know someone that can open the case and try to repair it you will need to send it in for repair.
Jan 05, 2011 | ASUS Eee PC 1000HE Netbook
I am going thro' a stack of video cassettes, and have decided to clean the head. I have a TDK tcw11 head cleaner and solution, but have forgotten to to use it. Please help.
Do you know the best way to clean the head of a VCR is to take the top of the VCR and use cotton buds and that fluid or better still Servisol Video 40. Wipe the head and any part the tape touches with a bud soaked in the fluid. Let it dry and put the cover on. You will make a better job than the tape and get rid of fluff etc out of the works. PS It will take more work if someone smokes where the VCR lives.
Jan 01, 2011 | TDK TCW11WET Life on Record VHS Wet Head...
Battery charger for craftman electric lawn mower model no 625 connector from charger to battery is broken and need new connector or complete charger
junked the charger connectors and replaced the connectors with better type of connectors that an old man can get a hold of to take apart to connect the charger when needed very poor design for elderly use.
Jun 13, 2009 | Craftsman Garden
Tdk da 5700 not recording
Cleaning will not help if it plays fine and does not record.
The previous owner was right, those can only record on "Music CD-R or Audio CD-R" . If it does not have that printed on the disc, it willnot record with it. many people think that a CD-R they use in the computer will work, but they won't. So make sure you are not using a CD-R meant for a computer.
Try using Sony, they work good for me on most all recorders I repair.
If that does not work, you may just need it to be serviced, or take it back to the guy you bought it from and get your money back. He sold you a bad recorder. They are very exspensive to repair most of the time.
Sorry I did not have better news, good luck and let me know if you need any more help.
Dave
Jun 29, 2008 | TDK DA-3826 2-Disc CD Recorder
Charger pins broken
you must change the charge connector exept if there are broken lines on pc bord.if the are the only solution is a desktop charger
Sep 11, 2007 | Samsung SGH-D900 Cellular Phone
Charging?
Your battery may have a low voltage, you need to rejuvenat is unfortunatly you cant do that if you dont have tools to do it, but that will be your problem (Battery)
Jan 10, 2007 | Motorola Mobility RAZR V3
TDK Life On Record Wireless Weatherproof Speaker Logo
1,188 people viewed this question
Top TDK Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
