Question about Car Audio & Video
My 1000/1 JL Audio amp connected to 13w7 keeps cutting out
Change your sub wires because you have the ohm impedance to low. try 2 ohms or look up wtf a ohm load is .
Posted on May 05, 2014
4 Suggested Answers
Jexx
  • 148 Answers
SOURCE: My JL audio 1000/1 amp does not work
Best bet is to send it back to JL, they do not sell the PCB with all of the components loaded on it. Most likely the transistors in the power supply have fried. Open it up and see if you can find any physical damage. Google the part numbers of the bad parts, and you should be able to fix it relatively easily. www.digikey.com is a great place for parts. Read this for more testing procedure: http://www.bcae1.com/ampfail.htm The whole site is wonderful, really.
Posted on Jul 16, 2006
  • 6 Answers
SOURCE: jl audio
i doubt that your factory alt can even think of keeping up with the 1000. it will draw up to 75 amps itself. just getting a cap wont help if your alt cant recharge the battery and the cap. it wont matter if you have 2 batteries and a 20 farad cap. best bet is to upgrade your alt to at least a 150 amp or higher. dont forget about the grounds and power wire upgrade too.
Posted on Jul 04, 2008
  • 150 Answers
SOURCE: jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Posted on May 12, 2009
My 12w7 has like a springing sound inside it, what is it?
Blown voice coil,,,,it was connected to a JL AUDIO amp correct? w7`s can ONLY be powered by JL amps due to ohm load.Advice buy a better quality sub,w7 is over-rated
Feb 07, 2013 | Jl Audio 13W7 Car Subwoofer
To hook a 1000/1 amp to 13w7 do i run positive to positive and negative to negative to the speaker
Yes yes never try to bridge this sub no reason if you had the money to buy this sub then you should have the right amp so.
Dec 24, 2011 | Jl Audio 13W7 Car Subwoofer
My 13w7 pops loudly when i turn it up. it is in a 2 cu ft sealed box. what do i set my amp at to fix this? the amp is a 1000/1 jl
If your Subwoofer is popping it could possibly be blown. when your radio is off slightly push in on your speaker if it kinda crackles it is blown. If you are using a sealed box put it in the middle of the box. if it is ported it needs to be on the opposite side from the port
Feb 14, 2010 | Jl Audio 13W7 Car Subwoofer
I have 2 jl audio 13w7 and 2 mono 1000/1 amps one for each woffer, one of the woffers blow. this set up is in a ported box. I was just driving to work bumping it like around 25 and the speaker startd to...
check your bass leval on your amp and make sure it is the same leval as your other amp. Also you w7 can be repaired they just change the coil. cheeper than buying a new one.
Sep 05, 2009 | Jl Audio 13W7 Car Subwoofer
I have a 13w7 in a ported box 2 exact jl specs hooked up to a 1000/1 and added an ole school klw audio phantom bass processer to it,with the bass down and the phantom knob on heavy it sounds like thunder...
Could be a range of things, a capacitor drying out, dust burning off, its hard to define without knowing exactly what the smell is. Ensure its as well ventilated as possible and keep a close eye on it.
Sep 01, 2009 | Jl Audio 1000/1 Car Audio Amplifier
JL Audio 13w7 & 1000/1 Amp Settings
that depend on how you wire the speaker my friend and the performance of you am and u have to use jl -dclass series amp for the best performance of those speakers
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
Oct 28, 2008 | Jl Audio 13W7 Car Subwoofer
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
