Question about Sony mhc-gzr888d mini hifi with 7 inch lcd screen-pal/ntsc for 110-240
Tray is not free at the eject position - Sony mhc-gzr888d mini hifi with 7 inch lcd screen-pal/ntsc for 110-240
How to unlock sony dvp- sr320
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Aug 10, 2015 | Sony Televison & Video
Disk will not eject
In some cases the disk tray will stick in the closed position. Keep trying to get it open with the actuator (open button) but if it fails, look for a small hole on the front panel and insert a small paper clip end into the hole, push, and the tray will open. By hand, sip the tray in and out several times to help free up the tray and remove dust or debris that collected over time.
Jan 05, 2015 | Westinghouse Televison & Video
Both cd trays are stuck in the closed positions and will not eject. How do I open the CD tray and eject ?
There is a belt for responsible they must replaced sometimes its possible to unlock the tray by a small paperclip but sometimes you have to disassemble the player with a 4 screws in order to achieve the ejection of the traymotor look most lying in front of the tray
Aug 17, 2014 | NexxTech N2000
How to eject CD
If the eject button on the CD player does not respond then straighten a paper clip and insert it into the tiny hole on the CD tray. Gently push the paper clip in and the tray will pop out, you can then pull the tray out to the fully opened position to remove the CD disc.
Mar 03, 2012 | Dell Computers & Internet
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
Sony DVP-NS50P not ejecting
hi,
You have to check the try loading belt of you dvd. if the belt is loose or broken the will not be ejected. you can see only OPEN in the display. You can simply check is it related to belt. Power on the dvd player and then press the eject button. Place you ear on the top of the player and listen is there is any humming sound (sound of motor running). If you hear the sound then the belt have some problem.if there is no sound then the problem is related to the electronic part which drives the motor. if so you have to change the mother board of you dvd player. Because the all the parts in it are smd( surface ***** device) also the availability of the part is very rare. Also you have to consult the sony authorized servicing center to repair the same.
If you here the sound then you Can rectify the problem by replacing the belt. Normally you cant see the belt from the top of the mechanism. Because it is beneath the tray. you can see it only if the tray is in eject position.
Remove the top cover of your dvd player. As it is sony dvd player you can eject the tray manually. for that watch the bottom of your dvd player. You can see a slot closed by a plastic strip just bottom of the mechanism. Pull out the plastic strip. Watch through the slot. you can see a Noach which you can move manually to the left and right. put a screwdriver in it and pull the Noach to the side. the try will get ejected. Not fully but partially. You have to pull out the tray fully manually.
If you closely look at the inner end side of the try then you cn see a motor and belt. if the belt is loose it will be in there in the motor pulley and in the wheel. if its broken broken then you have to find it where it . Take the belt as sample and bring a new one. you will get the belt at any of the electronic spare parts shop near you. Put the new belt in the position. inset the tray by pushing it in to inside slowly. power on the dvd player and the press the eject button.
ok
Apr 29, 2011 | Sony DVP-NS50P DVD Player
How to solve disc region error?
Here's how to make it region free..
1.Keep Tray in eject position
2.Press Setup from remot
3.Go to preference page
4.Press"138931"
5.Using Navigation Key change region code to "0"
6.Press "OK"
7.Regionfree!!
Jay
May 25, 2009 | Televison & Video
Multi region code
please try this
open tray
press 98790
OR
Press Setup from remote
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
hope it helps!
Nov 22, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
CD player damage
This can be a messy and frustrating problem to fix. You have to insure that the gears which control the opening and closing of the disc tray are correctly aligned with the apparatus inside. I have fixed this successfully on my own, but I must say it wasn't easy and involves removing the cover to give you better access, taking the tray out again and fiddling with it until everything is lined up properly. Might be worth sending for repairs.
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
Sony mhc-gzr888d mini hifi with 7 inch lcd screen-pal/ntsc for 110-240 Logo
42 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
