Question about Sony mhc-gzr888d mini hifi with 7 inch lcd screen-pal/ntsc for 110-240
Tray is not working normally
Tray is not freely at the eject position
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
How to unlock sony dvp- sr320
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Aug 10, 2015 | Sony Televison & Video
Both cd trays are stuck in the closed positions and will not eject. How do I open the CD tray and eject ?
There is a belt for responsible they must replaced sometimes its possible to unlock the tray by a small paperclip but sometimes you have to disassemble the player with a 4 screws in order to achieve the ejection of the traymotor look most lying in front of the tray
Aug 17, 2014 | NexxTech N2000
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
I can't open my DVD-RW disc
Hello and Welcome to FixYa!
If you are having problem with ejecting your optical drive please watch the video tutorial and follow the instructions.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Dell Latitude C610 Notebook
How can I manually open the DVD drive on SONY Vaio PCV 7762 desktop? The drive does not open. There is no DVD in the drive & to my knowledge it was not attempted to be open while in sleep mode, nor...
You can manually open the DVD drive by inserting a strsighten paper clip into a tiny hole just beleow the drive tray. Push the paper clip into this hole gently and the tray will pop out slightly, then grab the tray and pull it out until the tray is in the fully opened position.
Jul 30, 2010 | Sony VAIO Digital Studio PCV-RX860...
Hp 6110 printed page does not drop into tray freely
it sounds like the plastic pushers are broken off.
parts not available. sorry
Jan 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Disk tray ejecting
Have you got the xbox stood up as in the picture. If so, position it lying flat (so the cd drawer is horizontal) and then try it. If this works, I think it is just general wear and tear on the mechanism.
Rgds
Tony W
Aug 26, 2008 | Microsoft Xbox 360 Console
CD player damage
This can be a messy and frustrating problem to fix. You have to insure that the gears which control the opening and closing of the disc tray are correctly aligned with the apparatus inside. I have fixed this successfully on my own, but I must say it wasn't easy and involves removing the cover to give you better access, taking the tray out again and fiddling with it until everything is lined up properly. Might be worth sending for repairs.
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
Sony mhc-gzr888d mini hifi with 7 inch lcd screen-pal/ntsc for 110-240 Logo
41 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
