Question about GE Spacemaker JVM1640SJ Microwave Oven
Xl1800 trips circuit breaker
Oven runs for 5 seconds then trips breaker
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave
I repair GE circuit boards, but the problem is not your circuit board.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 19, 2008
SOURCE: Circuit breaker continually trips immediately when used
check for a shorted hi voltage capacieor ,transistor or shorted multiplier diode
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE jvm187osf02 microwave loses power
It may be a blown fuse or the thermal cutout (T.C.O.) or thermostat on the magnetron or on top of the oven cavity.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Posted on Aug 20, 2009
  • 21 Answers
SOURCE: Oven lost all power while running. No GFI's were
Hello
Check the fuse in microwave?
John
Posted on Jan 07, 2010
  • 2468 Answers
SOURCE: GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Posted on Jun 19, 2010
Why does it keep tripping a circuit breaker?
not cooking anything is not good for the microwave oven
There is a short in the system probably a failed magnatron unit that is continually tripping the breaker
Take it to an appliance repair shop and get a quote for repairs
Jan 01, 2016 | Microwave Ovens
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
The microwave unexpectedly turns off at random times during cooking. The clock face and everything dies. It is then a random amount of time (5-30) minutes before it comses back. It is not the circuit...
You could try a new plug just in case, next the fuse inside or thermal cut out could be @ fault, could be the cable transformer end as it enters the micro.....
Apr 19, 2010 | GE XL1800 1100 Watts Microwave Oven
15A breaker tripping; Is this the right size breaker for the unit?
The breaker is sized according to the size of the wire used in the circuit. The breakers task is to protect the wire from an over current.
The allowed sizes are
#14 wire .... 15 amp breaker
#12 wire ..... 20 amp breaker
#10 wire .. 30 amp breaker
To check if the oven and circuit are compatable .. run an extension for the oven to an outlet outside the kitchen and see if it holds.
Please Vote !!
Mar 08, 2010 | Hotpoint RVM1435 Microwave Oven
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
My RFS12MPS runs for around 5 secs, and then trips
Sounds like you have a intermittant shorting high voltage capacitor. I have had several of these that check good at rest then short after power is applied then un short by the time you put your meter on it to see if it is shorted. Best suggestion it to substitute the capacitor. The only othe rpossibility is you HV transformer is shorting out. You can completly disconnect the leads to the xfrm and run 120v to the primary. if it draws over 15 amps it is shorted. if it is shorted it could draw up to 30 amps. I would try subbing thecapacitor and if that does not cure it, it is most likely the Xfmr.
Aug 10, 2009 | Amana RFS12MPS Microwave Oven
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
49 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
