I have a rv duo therm thermostat and I am replacing with a Honeywell 2310 b model so what color wire goes to what terminal on the new one
It is a thermostat
  • 10,291 Answers
Depends on what colors the wires are Usually the red one is 24 volts , the black one is common. The green should be cool and the white should be heat
Posted on Mar 29, 2014
Duo therm rv ac. Model57915.622 fan won't turn off? S
The new thermostat may have been set accidentally for constant fan.
May 26, 2018 | Heating & Cooling
What replace Duo Therm Thermostat 3105356.001
Can you attach a picture? Does it look like this one?
Jan 14, 2013 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
How do I install a blower motor in a duo therm model 57915.622? What tools will I need?
ITS NOT EASY. YOU NEED A LONG SET OF ALLENS TO LOOSEN BLOWER WHEELS. THIS IS A  DUEL SHAFT MOTOR , BACK COIL NEEDS TO BE PULLED AWAY FROM MOUNT WITHOUT BENDING COPPER. MOTOR BOLTS 3 OF THEM HAVE TO BE REMOVED AND WHEN BOTH BLOWERS ARE REMOVED AND WIRES REMOVED THEN IT CAN BE REMOVED . THE PROBLEM IS THAT THE NEW MOTOR IF IT IS NOT FROM DUO THERM YOU WILL HAVE TO CUT SHAFT TO RIGHT SIZE AND WIRES MAY NOT BE SAME COLOR. IF IT IS SAME MOTOR FROM DUO THERM YOU CAN CUT WIRES AT OLD MOTOR AND WIRE NUT THEM COLOR BY COLOR.
Apr 19, 2010 | Dometic Rooftop RV Air Conditioner
I have an old mobile home that has and old duo therm thermostat that is acting up. keeps cycling off for quite awhile and on for not so long. I purchased a honeywell ct-31-a. It only has places for 4...
If you want just heat, connect the red wire to the R terminal, the White wire to the W terminal and the green wire to the G terminal. Confirm that these same wires go to the same terminals on the control in your furnace. If you want both heat and air conditioning, connect a jumper from R to R2. Keep the wires the same as I described and put the yellow wire on the Y terminal.
Feb 01, 2010 | Honeywell Heating & Cooling
Trying to connect kenmore heat pump thermostat to honeywell therm
reversing valve orange wire goes to o or b terminal depending if energized in heating or cooling
May 11, 2009 | Honeywell Programmable Thermostat Heater
Help - I am trying to install a honeywell RLV4300A
You will have to have schematics from the old wiring diagram. Then you will have to confirm its consistency with actual old wiring before you can be sure that the wires run to the proper places on the old heater and a/c system. This sounds like a gas furnace and is simpler than a heatpump. Once you know what distinguishes the wires with the same color, you should label them and then you may call them a different color if they were wired with wrong wire colors. You may be in luck if you go to the furnace control box an look at the terminals.. They are usually labeled with a R for Red and W for white and Bl for Blue and B or Black. If you have other colors on these then it sounds that it was wired with wire spare wire by someone who knew what they were doing but neglected to leave a path for someone else follow.
You may be able to use a continuity tester of circuit tester to id these wires that are in question...
ie, once indintified, you can match with the requirements of the new stat.
Jan 10, 2009 | Honeywell Electronic Programmable...
Thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Rv air conditioning
You may have to remove your filter & look for a model # of your unit, so we can pinpoint your wiring to the thermostat. Usually the terminals on the thermostats are labeled -RC-RH- etc, and you simply move old to new of the same. A lot of times some manufacturers will use phone cable form AC unit to thermostat, and mix up the colors, that's the reason for going to the AC and see what color is used from there. It could be red from control box, connected to green wire to thermostat for example. Thats where you note it and wire accordingly.(terminal calling for red wire, would now be green) If your stumped, get back to us with that model#.
Jul 12, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
