Sart-up trouble. My pc is having trouble at start-up. About 5 seconds after It's turned on the foxconn (my motherboard brand) logo appears with the options to go into alternate menus and such.This had happened before, usually its fine and continues to boot the login screen. For whatever reason it's freezing on the foxconn screen or jumping to some data list which I believe is  a list of  components. Any idea what I should do?
  • 656 Answers
I think in the bios set it as defult configration or user orginal configration i think some components in bois may be enabled
Posted on Nov 30, 2007
Program for donwloaud bios (foxconn logo)
Hello visit the foxconn homepage here:
http://www.foxconnsupport.com/download.aspx
And enter the mainboard number, in seach for the software.
Foxconn has made many mainboards for different brands, so you can also try at the pc`s homepage (not the mainboard)
Good luck
Feb 13, 2013 | Computers & Internet
EVGA Geforce 8400GS is compatible with FOXCONN G31MV-K Motherboard?
Check your installed ram sticks. (one at a time) the card is compatible with your board But the problem may be with your operating system and not the hardware. on start, press F8 and select "Last known good config" if the system still fails you may have a duff card.
Jul 21, 2012 | Evga GeForce 8400 GS Passive 1024MB DDR3...
My 4gb android 2.3 os wont sart up past the second android logo
bad sd memory card, try removing and restarting. If that works, replace sd card.
Jul 12, 2012 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
Have a Dell Studio. When I power up the Dell Logo appears with loading bar below that. The bar stops about 2/3 of the way, it freezes up and starts beeping. Nothing I've tried works.
this is often related to a possible motherboard problem. Try these steps: turn it off, remove the battery, and AC adapter, then press and hold the power button for about 5 to 10 seconds. Once done, reconnect at least the adapter , turn on the laptop and as soon as the Dell logo shows up, tap F2 a few times to enter System Setup (BIOS screen). From there, go to the Maintenance category, and select Load Defaults, press Enter. Press ESC, then select Save/Exit, restart the computer and see how it goes.
Sep 27, 2010 | Dell Studio 15 Laptop
BIOS wont start
Check the battery voltage. The battery may have failed and is overloading the AC pwer supply.
Aug 28, 2009 | Acer Aspire 5315 Notebook
The pc did not turn on
It looks like your HDD or ROM has problem. Mostly your Hard Disk must have failed.
Apr 17, 2009 | Computers & Internet
Winfast k8s755A freezes at startup
Ok I got e-mail from Foxconn and they told me to use a single sided 256 DDR RAM to get past post. So I did, then I wnt to BIOS and set all my settings, saved it restarted turned off the PC then returned my 1GB Ram then all worked just fine. This is an issue coused by haveing a Samptron 64 CPU.
Nov 21, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Help with motherboard
The keyboard should work, unless it is a usb keyboard, the drivers have not had chance to load because you are still in basic dos. Try a PS2 keyboard if this is the case.
Jan 15, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Computers & Internet Logo
402 people viewed this question
Alun Cox
David Payne
David Payne
