Question about LG WM-2277HW Front Load Washer
Washer is not grounded properly
My washing machine does not start unless I get a spark from the wall socket when I plug it in. How do I fix this?
    New Friend:
  • 23 Answers
Have the outlet checked by an electrician or qualified person to be sure the ground wire on your outlet is properly connected or that you have a good working outlet
Posted on May 16, 2014
How to reset a Fisher Paykel eco smart top loading washing machine
With any appliance like this, all you need to do it remove the plug from the wall socket, wait 30 seconds and then plug it back in. If a fault code still appears then you will need to have the machine repaired.
Jul 08, 2017 | Fisher Washing Machines
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Why won't the drum on my washing machine spin and can I fix it myself without too much difficulty ?
UNPLUG WASHING MACHINE FROM ELECTRICAL SOCKET.REMOVE BACK PANEL FROM WASHING MACHINE AND CHECK ALL BELTS ARE ON THE PULLEYS OR WORN AND NEED REPLACING. IF BELTS ARE OKAY REPLACE BACK PANEL AND REPLACE PLUG INTO ELECTRICAL SOCKET SWITCH WASHING MACHINE ON THEN TURN OFF AT WALL SOCKET. WAIT FOR FIVE MINUTES EXACTLY. PUT A TEA TOEL IN THE FRONT LOADER, TURN ON WASHING MACHINE AND PROGRAM TO SPIN RINSE, PRESS START BUTTON AND ALL SHOULD BE WELL. GOOD LUCK!
Oct 17, 2014 | Tricity Bendix Biw125w Washing Machine...
Ecomax400 - Continual cycle - won't turn off unless unplugged at socket!
Please specify that wont stop means filling or washing or rinsing.
Jul 30, 2014 | Hobart Dishwashers
Machine will not power up. No lights at all can you help please?
have you checked the fuse in the plug? try replacing it, or plugging into another wall socket, also check the actual socket it is plugged into works by plugging something else into it. If none of the above works then looks like you have a problem... first check would be to turn off the power at the wall and check the whole power cable from start to end looking for any splits or possible kinks or areas where a mouse or rat could have chewed it perhaps...
Jul 10, 2014 | Fisher and Paykel (IWL12)
Cl code error how do i get rid of it.
Norah, The simplistic fix might be to unplug the washing machine from the wall socket, wait 5 minutes plug it back in and see if that clears the error.
Jan 29, 2014 | Bosch Washing Machines
Washer does not start, replaced lid switch, and timer still doesn't work. when parts mentioned were replace. washer did start and fill but then stopped.
Hello there and welcome to fixya
I am sorry to hear that you are having problems i will post some information on some more parts that need to be tested ok?
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Sep 24, 2011 | Maytag Washing Machines
Have a GE Select washing machine that won't start or operate ? Can you help ?
Hello there and than you for choosing fixya
Feb 06, 2011 | Washing Machines
Change the spark plugs
you need a special socket for your car. its deep socket with thin wall. what i did was to bring my socket to a machine shop and made my tool thinner
Jun 02, 2009 | 1999 Mitsubishi Galant
Hoover VHD Washing machine
Surely it is the wall socket.
Mar 19, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
55 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
