Question about Samsung ML-2510 Laser Printer
Cannot print on line - Samsung ML-2510 Laser Printer
I got new checks and the print is now not lined up on the lines when it prints, also, the printer does not recognize the paper
Quickbooks has a print option where you can adjust how the checks print. I have always made a copy of the blank check and adjust the settings until it prints on the line. If you keep making adjustments you can get it to print almost
perfectly.
Mar 08, 2018 | HP Photosmart C6180 All-In-One InkJet...
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
May 29, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
Nov 09, 2017 | HP Photosmart 2710 All-In-One InkJet...
My multipass f30 prints two lines skips a line prints two lines,
Try going to the "menu" button and look for "printer settings", then "cleaning" on the display.
Feb 21, 2009 | Canon MultiPASS F50 All-In-One InkJet...
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Nov 23, 2008 | HP Photosmart 8450 InkJet Printer
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
Jan 17, 2008 | Office Equipment & Supplies
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Samsung ML-2510 Laser Printer Logo
15 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
