Question about Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET
I woke up to no water my pump kicks on and hums for 3 to 5 seconds and quits
Where is the starter switch
  • 3,368 Answers
It sounds like it is seized with the overload relay cycling it to save the motor. It needs to be dismantled, cleaned and possibly rebuilt. Check the price of a new one it may be cheaper.
Posted on Jun 13, 2014
Pump is running/humming, but not grinding
The pump may have become plugged again immediately
May 28, 2013 | Star Water Systems PowerFlush Sewage...
Just quit running when you turn key over should you able to hear if fuel pump is kicking on
The fuel pump will run for about 1 second only and then the system computer shuts it off unless the engine starts or is being cranked over with the starter motor, so repeatedly turn the key off and on to keep it running or at least supplied with power. You will hear a low hum near the filler neck if the pump is working. I have this same truck and have replaced the fuel pump twice. One hint never run the fuel level lower than 1/8 tank or the fuel pump will overheat and that shortens the life of the pump dramatically.
Oct 15, 2012 | 1998 Dodge Dakota
Hyundai accent 2001 will not start all lights work radio works heater fan works battery in 3 months old when I turn the key all i hear is a humming sound for about 1 min. than nothing. weather has be
The humming would be the fuel pump coming on. It should only hum for a few seconds, then shut off.
Your problem is with the start circuit from the battery to the starter, or from the ignition switch to the starter solenoid. Check the connections at the starter (the big cable) for tightness.
Is the battery charged up enough to turn the engine over? Check by turning headlights on and observe while someone turns key to crank. If they dim a LOT, then either battery is too low, or the starter is bad and needs removing for testing. If brightness doesn't change, then the circuit from ignition switch to starter solenoid is likely not working. Check for 12 volts at the small wire to starter solenoid with key in cranking position. If you have power there, the solenoid may be bad. Remove starter for testing. If no power at solenoid in starting position, then either the ignition switch is bad or the neutral safety switch might be the problem, or the wiring from the switch to the starter solenoid is not passing current.
Good luck.
Jan 14, 2012 | Hyundai Accent Cars & Trucks
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
Motor hums then clicks off
Has the motor seemed a little slower in starting than usual? If so then you probably have a weak or defective motor capacitor. Try switching out with a new one.They are inexpensive.Try to turn the motor shaft at rear (under end cap) while it attempts to start. If the motor kicks on then replace capacitor.
Apr 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My Whirlpool Fridg. Model ED22RF has a problem. The freezer is defrosting and neither side is cold. Sounds like the compressor switch is kicking on for a second and then off but the compressor never really...
yea that sounds like a compressor issue( under 5 year manufactrue warr.) you can try replacing te overload/relay assy mounted to the side of thecompressor , sometimes you get lucky and it works part number 4387767
Mar 26, 2008 | Refrigerators
Frige not cooling
what do you expect from crap made in china?? Quality?? Huahahahaha
Jan 07, 2008 | Haier HSB03 Compact Refrigerator
It fills, but doesn't kick in to spray/wash
Main pump not running?...then it will either be the program controller or the main pump itself.....I would guess the pump first.
Jul 17, 2007 | Kenmore 15522 Built-in Dishwasher
Utilitech 1/2 HP Convertible Jet Pump 1/2C-JET Logo
199 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
