Question about RCA 32LA30RQD TV
32LA30RQD NO PICTURE NO SOUND - RCA 32LA30RQD TV
TV model 32LA30RQD is leaking at the bottom, a yellow oily substance...what is it & is it toxic?
Could be a number of things electrical, some corrosive (e.g., a leaky filter capacitor). Best to get it into the shop.
Sep 27, 2017 | Televison & Video
32LA30RQD WILL TURN ON BUT ONLY BLUE LIGHT
Check all the input signal connection cables for no loose fitting. If found OK, check and replace its tuner. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 28, 2015 | Televison & Video
My tv turns off after being on for a short period of time.
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Apr 25, 2015 | RCA 32LA30RQD TV
I have a RCA 32LA30RQD television that will turn on for roughly a minute or so and then shuts off and will not turn back on. Is there anything I can do to fix this issue?
when it turns on do you have a picture? if the TV sees no signal it is suppose to shut off. if you do have a picture than you have a damage power supply
Nov 05, 2014 | RCA 32LA30RQD TV
Rca 32LA30RQ codes for directv
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
CQC08001026140 RE46LK1300 Leke LK PI320402A Power Supply Backlight Inverter
Apr 07, 2014 | RCA 32LA30RQD TV
I have a RCA 32la30rqd that has a logic problem
You really should not have a problem with a different manufacturer. It is common to have one manufacturer contract several companies to make the same board.
Apr 03, 2014 | RCA 32LA30RQD TV
Rca
Check your power outlet for any loose contacts. Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | RCA 32LA30RQD TV
RCA 32LA30RQD TV Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
