Question about Konica Minolta bizhub Office Equipment & Supplies
Margin gets cut off while scanning to email on konica minolta bizhub 250
  • Konica Minolta Master
  • 6,161 Answers
Document feeder may be not properly aligned, get tech out to adjust it.
Posted on Jan 24, 2016
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: konica minolta bizhub C252 printer Problem
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
Posted on Jul 06, 2008
  • 6 Answers
SOURCE: Konica Minolta 250 Bizhub scanning Operations
what u need to scan to emails is the email smtp ip address.
just put the ip smtp address in the network setting>smtp address
and try to ping from ur B250, if the result is OK, then u have the connection. go to Utility/Counter>user setting>one touch to register
the user address, then scan it, u should be getting the scanned file in ur inbox.
Posted on Aug 09, 2008
  • 1294 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
  • 19 Answers
SOURCE: how to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
Posted on Jul 28, 2010
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
May 20, 2010 | Konica Minolta Bizhub c203 Copier
How can i add client pc to scan from konica minolta bizhub 250
HI U must have CD driver to istall twin driver in ur pc and conect usb cable the leed in the right [ + ] will light up if no call ur service
Dec 28, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub 250 I need to scan many documents to computer says user id and password incorrect
the user name and password have to match the pc. if the pc does not have administrative rights the scan will be rejected most network security software will cause a scan to be rejected also
Sep 25, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 jammed but no paper
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
When making multiple copies some of them come out with the margin cut off and the others come out fine
are the side guides all the way up against the paper in the paper trays if so then the registration clutch probably needs to be replaced
Jun 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Mar 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Scanning a combination of one-sided and two-sided documents
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Oct 17, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
43 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
