Question about Craftsman Sears Snow Thrower Manual Model No 536.887250
How do you replace a leaking primer?
I pressed the primer and it began leaking gas. I believe the rubber had aged and could not withstand the pressure.
    Sergeant:
  • 458 Answers
You must go through Sears to get the parts you need.
Posted on Feb 17, 2014
Fix or repair gas leak.
no rino lining will not withstand gas. J B Weld has a product that will work but generally once a gas tank has corroded enough to leak you are better off changing the tank
Feb 18, 2015 | Cars & Trucks
Gas is leaking from the primer on my swisher walk behind trimmer. What would cause this?
i believe you have a cracked primer bulb or cracked fuel line. you should also check and see if the screws are loose that connect the primer bulb to the assembly.
Sep 25, 2013 | Swisher Walk-Behind High-Wheel String...
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
Idles ok revs up and stalls out
Aug 13, 2013 | Poulan Garden
Tecumseh 5 hp snowblower carburetor adjustment
Having to run the engine with choke on indicates that there is an air leak somewhere in the fuel delivery. Check the gas line for cracks, and if your model has a primer, the hose from the primer to the carb may be cracked.
Dec 21, 2012 | Garden
Gas is leaking through carb
If you have a rubber push primer on your mower, you will need to change the rubber gasket for the primer or the feul will continue to run out
Sep 05, 2012 | John Deere Garden
Under the primer bulb is a orange rubber check valve. Can you buy that without buying a complete rebuild kit?
The rubber check valve is part of what is called the primer base assembly. That is a part all unto itself and includes the check valve. Here is a carburetor break down with parts and diagrams.
http://www.lawnmowerpros.com/PDFs/Zama/C1U_PARTS_LIST.pdf
May 13, 2011 | Ryobi Garden
Unsafe gas line repair?
It is ok, as long as the hose is for fuel, and the hose is designed to withstand the pressure,and everything is done tight without leaks.
Aug 16, 2009 | 1989 Dodge Raider
Carb will not shoot gas in engine w/primer.
Hi, check the primer rubber too see if there is small leak in it. and replace the gas tubes inner and outer
If this doesn’t work for you please write back. Thanks,
Nov 17, 2008 | Husqvarna 160 CC Honda OHC Engine 21 in
Craftsman Sears Snow Thrower Manual Model No 536.887250 Logo
59 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
