Question about 2004 Ford Escape - Automatic, 3.0L V6 - Performance Module
Cant shift it from park to drive its stuck
Cant shift it from park to drive. its stuck.it has to be parked on a level road
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 120 Answers
Make sure battery is charged and apply brake pedal and have ignition on. if this fails you have a problem with either the signal from the brake pedal or the ignition switch. check if your brake lights are working, could be the stop light switch
Posted on Feb 21, 2014
Why cant i shift my 03 nissan altama out of park
Check to see if you have brake lights. No lights, replace the brake switch at the pedal. This will fix the park problem. If you have lights, then it could be wiring or a bad solenoid at the shifter.
Sep 10, 2016 | 2003 Nissan Altima
HOW TO UNLOCK YOUR FORD TAURUS GEAR SHIFT
Search Results
    Ford Focus Questions - the car starts up but i cant get it out ...
    www.cargurus.com > Questions > Ford > Focus
    CarGurusJan 26, 2013 - the car starts up but i cant get it out of park the button on the shifterwont ... point the shift interlock will allow you to shift to neutral and other gears with ...That should expose your shift lock over ride button. .... Used Ford Taurus".
    97 Ford Taurus gear shift stuck in park - Car Talk
    community.cartalk.com/.../97-ford-taurus-gear-shift-stuck-in-park
    Feb 7, 2009 - Over the past week, it has been difficult to get the gear out of park. ... 97Ford Taurus gear shift stuck in park ... LOCK, then remove the key. 2.
    Why Wont My Car Shift Out of Park - Shifter Interlock ...
    ? 3:49
    https://www.youtube.com/watch?v=ZdDsfNrabsM
    Mar 21, 2014 - Uploaded by BleepinJeep
    Only problem is if it fails, you cant get your car out of park. ...Those interlocks seem like they might be a solenoid that slides alock pin out so that you can move the lever freely. .... Someone told me it was possibly the Passing gear cable ? ... Ford TaurusWon't Shift Out Of Park, Brake Lights Don't Work With ...
    Car stuck in Park, shifter won't move. - DoItYourself.com ...
Jan 18, 2016 | Ford Cars & Trucks
Gear shift locked in park
Try setting your parking brake before you put the gear selector in park. Then put it in drive before you take the parking brake off to see it it keeps the load off the transmission when your parking on a steep incline or decline.
Apr 26, 2014 | Ford Cars & Trucks
Gear shift stuck in park
if parked on a slant pressure on pin will make it hard to get out of park.try rocking it back an forth while trying to shift.
Jan 31, 2014 | GMC Jimmy Cars & Trucks
Needing to troubleshoot transmission problems for my 2001 pontiac grand prix
It can be issue with transmission,most probably it needs to be rebuilt.
Also get the ****** fluid checked. If it's low, then such problems occurs.
To troubleshoot these types of issues, check the actual solved problems with these types of issues.
There are solved help links provided below: -------
Click the link below and go through the details and diagrams to troubleshoot the problem: -----
2003 Lexus RX300: Transmission Fluid Burnt Brown and not Shift to reverse?
http://whatisbyme.blogspot.in/2012/05/2003-lexus-rx300-transmission-fluid.html
2007 Chrysler 300: Transmission Stuck in Park?
http://repairhelpcenter.blogspot.in/2012/06/2007-chrysler-300-transmission-stuck-in.html
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
1996 Toyota Corolla: Transmission Shift Interlock will not Release?
http://technoanswers.blogspot.in/2012/04/1996-toyota-corolla-transmission-shift.html
Lexus LS400: Transmission or Torque Converter?
http://technoanswers.blogspot.in/2012/04/lexus-ls400-transmission-or-torque.html
CV AXLE stuck in Transmission?
http://technoanswers.blogspot.in/2012/04/cv-axle-stuck-in-transmission.html
Transmission in reverse, acts like it's in neutral? http://schematicsdiagram.blogspot.in/2012/04/transmission-in-reverse-acts-like-its.html
Delayed shift and harsh Shifting?
http://schematicsdiagram.blogspot.in/2012/04/delayed-shift-and-harsh-shifting.html
Dodge neon wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Dodge Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Dodge manual transmission will not go in reverse gear?
http://technoanswers.blogspot.in/2012/02/dodge-manual-transmission-will-not-go.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
1998 Dodge Ram: Not Shift To Reverse? http://schematicsdiagram.blogspot.in/2012/06/1998-dodge-ram-not-shift-to-reverse.html
Transmission leak on Toyota?
http://schematicsdiagram.blogspot.in/2012/02/transmission-leak-on-toyota.html
Automatic transmission, with no reverse?
http://howtobyme.blogspot.in/2012/02/automatic-transmission-with-no-reverse.html
No Movement When Transmission is Shifted to Drive or Third?
http://schematicsdiagram.blogspot.in/2012/03/no-movement-when-transmission-is.html
While going in reverse mode Fuse number 27 blows on Ford Ranger?
http://howtobyme.blogspot.in/2012/02/while-going-in-reverse-mode-fuse-number.html
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"? http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html --------- 2006 Chrysler 300c: Shifter Stuck in Park? http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html ---------- 1998 Ford Expedition: Will not Shift Out of Park? http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html --------- Car will not move when in gear? http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ----------- Mercedes-Benz transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ---------- Mercedes Benz not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ---------- Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
------- 2007 Ford Expedition: How to shift car in neutral with Dead Battery http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html -------- 2002 Nissan sentra will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html -------- Nissan Sentra stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html --------- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
----------- Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
-------- Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
------------ No First gear Starts In Second Gear http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html ------- Ford Taurus won't shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html --------- 2006 Ford F150: Will Not Shift out Of Park? http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html -------- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
---------- 1998 Chrysler Voyager: Transmission Problem? http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html ------ Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
-------- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
-------- Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
---------- 2002 Chevrolet Avalanche Z71: Gear shift Issue? http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html ---------- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
-------- Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--------- Transmission-Hard To Down Shift http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html --------- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------------ 2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode? http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
2004 Trailblazer shifter stuck on Nueutral can't move to park or Drive
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
--- Car wont downshift sometimes?
---- Transmission will shift into drive?
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
------- Vehicle has whining sound in gear?
------ Gear shifts hard?
------- Vehicle noticed sluggish delayed shifts while driving?
This will help.
Thanks.
Feb 04, 2012 | 2004 Chevrolet TrailBlazer
Sometimes the automatic transmission shift in my 91 Firebird gets stuck in park and will not shift into drive or any other position. could this be because of the shift lock solenoid failing? what other...
Could be the brake safety switch, there is an override for it, consult your owner's manual or check with the dealer for the location.
If you are parked on a grade (hill) it will put pressure on the parking pawl and make it hard to shift out of park. If you park on a non-level surface, put the parking brake on while you still have your foot on the brake in drive, then put it in park.
Aug 28, 2010 | 1991 Pontiac Firebird
2006 Chevy Impala stuck in park
When you turn ignition on it releases a cable that is attached to the shifter also the shifter has a solenoid attached to it that is released when you step on the brake. Both times that I had the problem of button stuck and cant shift out of park the solenoid was sticking and wouldnt release .
Dec 20, 2008 | 1998 Land Rover Discovery
2004 Ford Escape - Automatic, 3.0L V6 - Performance Module Logo
85 people viewed this question
Top Jet Vehicle Parts & Accessories Experts
Roger W Stone
Level 1 Expert
Sathish kumar
Level 1 Expert
Richard Warren
Richard Warren
Are you a Jet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
