Question about Hotpoint Washing Machines
Hotpoint wmf520 remove dispenser drawer - Hotpoint Washing Machines
How to remove the detergent dispenser drawer aquarius WML 520
Instructions for the machine, and specifically the detergent dispenser drawer, are here:
http://www.manualslib.com/manual/70853/Hotpoint-Wml-520.html?page=10#manual
It does NOT show how to remove the drawer. It is likely that the top of the machine must be "popped off" to do so. The best advise is to search for a Repair Manual if you simply must get the drawer out. I believe one of the manuals shown on this webpage may be the repair manual:
http://www.index-of-pdfs.com/hotpoint-aquarius-wml-520-user-guide-pdf.html
Most washing machine tops are simply a pressure fit that snaps on to the body. A firm grasp on the front sides of the top and a brisk pull may well pop it off.
Be sure to unplug the machine before you attempt any service!
Washing machines can be full of water AND electricity. That is most certainly a recipe for one, big, hydro-electric
Aug 04, 2014 | Washing Machines
Hotpoint Aqualtis throws water out of soap draw during rinse. Have checked pressure switch & tubing. How do you get to the pressure chamber to check for blockage? Could it be anything else?
I would remove the dispenser drawer by pressing on the release button, then clean out under the drawer. The reason I say this is I have had a few do this and I found a rinse agent clogging unit it cause the water during rinse to dispense forward and leak on the floor. It not difficult to clean out, this can take up to 10 minutes or so to fix with no parts needed.
Good Luck
Aug 31, 2011 | Hotpoint Washing Machines
How do i clean the soap powder dispenser drawer? Can it be removed?
There should be a clip in the middle of the top of drawer you press this down quite hard to see it ,this then allows tray to be removed easy for cleaning
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius WM32. Will no longer use the conditioner from the dispenser drawer. dapchiles@talktalk.net
There is probably a blockage in the drawer.
Remove drawer and thoroughly clean all parts, making sure there is no residue of powder or conditioner in any of the compartments.
Nov 20, 2010 | Hotpoint Washing Machines
How do I remove the powder draw from the aquarius wml520, please?
1. Extend the dispenser drawer until the stop is reached.
2. Press the locking tab located in the centre rear of the drawer and pull the drawer out.
Mar 19, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Can I remove the detergent drawer in a hotpoint hvl241?
There should be a release tab in the dispenser, push down, pull out
if NOT
Remove the screws along the rear top of the washer,lift the top, remove.
Nov 08, 2009 | Hotpoint Aquarius WF220 Front Load Washer
WD 63
Remove dispenser drawer from m/c, and thoroughly clean it and all accessories.Clean all residual build up of undesolved powder and conditioner in drawer compartment..
If it still leaks, then remove top cover, locate large black hose at bottom of dispenser, and give it a good squeeze to clear any possible blockage in the hose itself..
If still no better, could be due to exceptionally high water preesure forcing the water out of the drawer.
Turn cold water valve down a little to reduce pressure.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD71 washer/dryer
Hello farijl,
Welcome to Fixya,
You said, Water gushing from powder dispenser drawer. I have been told to take out drawer and put to one side. Looking into drawer space at back on right hand side there is a hole to be unlocked. It is so scaled up I cannot see hole. Can you help me or do you have an illustration fo what I am supposed to be looking at and unblocking ? Hope you can help soon. Floor is flooding every wash and cannot afford to get man out.
I found what you are looking for!
Below I will post the site for your WD71 User guide.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/531INST_016437770-02_WD71.pdf
If you scroll down to page 5 it will show you what and how to remove the transit brackets.
the dispenser drawer info is on pages 19 and 20.
My first post was incorrect about the bolt.
The American washers us a bolt!
Sorry.
You should be fine now and able to remedy this by your self
Let me know if you have any other questions.
Huuum
Please remember to leave a rating
Thank You
The detergent dispenser
will not close properly or is
collecting water?
1. Check the drawer is properly aligned.
2. Clean the dispenser drawer (see Care and Maintenance).
Oct 17, 2008 | Hotpoint Ultima WD72 Front Load...
SOAP DISPENSER HOSE
take both star screws from under lugs on either side of the lid remove that then take soap drawer out if screws are not visable remove front facia panel the same screws which hold the facia will also hold the soap drawer in place as you lift the drawer you will be able to undo the hose to the drum.
Mar 08, 2008 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
