Question about Siemens HF87951 800 Watts Microwave Oven
Siemens HF23556 bulb replacement - Siemens HF87951 800 Watts Microwave Oven
Replace bulb in Siemens microwave ?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Apr 26, 2016 | Siemens Microwave Ovens
How do I change the light bulb?
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 09, 2011 | Siemens HF87950GB Convection Microwave...
My Siemens HF87950GB inner glass panel broke during cooking, do I need to replace the whole microwave oven or just the glass or the door? where I should I go to get a replacement? Thank you!
This is a problem that at least a few others have experienced with your microwave and may be the subject of a recall although I could find nothing on their website.
I would definitely go to Siemens first as this definitely sounds like a manufacturers defect. Even if they have not publicly stated this in a recall, they likely know it is happening and may fix it (even out of warranty) if you push. ConsumerReports.org may be interested... I would talk to them if you don't get any satisfaction from Siemens.
Otherwise, the glass should be standard tempered glass that a local glass shop can get if you bring the door to them, or just a sample of the broken glass (for thickness) along with the internal dimensions of the glass.
Make sure that the metal mesh/screen remains in place and is not damaged, as this is what prevents the microwaves from escaping the cooking chamber.
Siemens Customer Support Website
Siemens Service # 1-866-447-4363
Oct 21, 2010 | Siemens HF87950GB Convection Microwave...
How to change the light bulp inside the oven?
Bulb replacement is not straight forward on this model, it requires the oven to be removed & stripped to gain access to the interior lamp... I recommend replacement by a Siemens engineer.
Mar 02, 2010 | Siemens HB77L25GB 900 Watts Convection /...
How do I change the bulb on Seimens Microwave HF75950GB/02 ? Doesn't seem to be obvious way to remove glass cover.
remove the guide vane cover off then.Move unit forward out from enclosure about 20cm. to get to the light bulb .the light is covered by a small panel on top of the casing.Remove lid and replace bulb! .hope this helps do let me know
Jan 12, 2010 | Siemens Microwave Ovens
HF87960GB Need to change lightbulb,how? Cant seem to locate it can anybody help please, Tony
on the top of the oven there is a plate with 2 hex screws, just undo these and your see a bulb and BINGO!
Oct 17, 2009 | Siemens HF87950GB Convection Microwave...
Interior light out. replace bulb
Ifthe owner's manual doesn't cover it and there's no obvious coveron the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
The light is often located on the right side in the air duct attached to the magnetron or above the cooking cavity.
Mostbulbs can be matched up at hardware stores, home improvement centers,and places like Wal-Mart or even large grocery stores.
Sep 17, 2009 | Siemens Microwave Ovens
How do you replace the internal bulb in the Siemens HF87950?
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 02, 2009 | Siemens Microwave Ovens
Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Apr 11, 2007 | Siemens HF87951 800 Watts Microwave Oven
Siemens HF87951 800 Watts Microwave Oven Logo
105 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
