Question about Garden
Lift assist spring replacement jd x320 - Garden
3 Suggested Answers
moretons
  • 155 Answers
SOURCE: JD X320 blades stay engaged, always. Narrowed it
Hi you can adjust the gap on these clutches , The recomended gap is 0.10 thou you slide this size feeler guage into the hole on the side of the clutch there is three holes and three adjusting nuts you have to try and get it even .
Hope this is some help
Mark.
Posted on Jul 23, 2009
  • 41 Answers
SOURCE: jd X320 will not start changed fuel filte,spark
I assume it cranks, but won't fire up? Make sure the choke lever is moving the linkage in front of the carb. If so, tap the carb bowl lightly with a wrench. (That fixed mine once, and it never did it again) Have you had your valve lash adjusted? Be sure the carb is getting fuel. Pull the fuel line off the carb, and try to crank it... My X320 has 1,500hrs on it, and I have had great luck! Keep me posted, I want to help you get this figured out!
Posted on Oct 07, 2011
What Gator Blades will work on a new X394? (48A) deck
They are different blade LOW lift blade and HIGH life blades. Sound like you have to change to HIGH lift blades
Sep 22, 2017 | Garden
How to fix JD x320 grass height level and blade engagement
Check if lever come unhooked or a stick or something blocking it.
Oct 21, 2014 | Garden
Jd X320 will not start changed fuel filte,spark plugs,and checked air filter
Oct 06, 2011 | John Deere Garden
Replaced Mower Deck Drive Belt. Belt runs from Engine pulley to Mower deck Pulley. Purchased new belt rom JD dealer. Belt is slack, Is there suppodes to be a tensioner for this belt.
Yes, there is an idler arm with a pulley that presses either inward or outward against the belt to tension it. In some JD mowers, the arm is tensioned by pulling on a long metal rod that latches near the edge of the mower deck, but without the model number I can't be more precise about that. Just look for that extra pulley and arm it's mounted on -- you'll see a tension spring, and you should also see a way to pull the arm away from the spring to place it under tension. Good luck!
Aug 15, 2010 | Garden
Need a rebuild kit for the hydraulic cylinder that lifts the snowblower - does such a kit exist and what is the part number?
there are rebuild kits for some but not all, check your local jd dealer, my family ownd a jd dealer until last year jd stuff aint cheap. personally id type hydraulic cylinders into google and buy a replacement
Nov 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
JD push mower doesn't have enough power to throw
I would have a compression check done on the push mower,if it has bad compression the engine needs rebuilt or replaced. As far as the bent bracket,if you can straiten it thats what I would do,mabey get a torch an heat it first.
Aug 02, 2009 | Peg Perego John Deere Farm Tractor and...
The door to my miele dishwasher does not spring closed and just lies flat when opened
The operative word is spring[s]. There are two springs to assist in lifting the door. One on each side. If your dishwasher is an older modell it is time to replace the springs because they are worn out.
Jul 18, 2009 | Dishwashers
Mark.
Jul 18, 2009 | Garden
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
