Question about Ovens
Broil timer not holding and error code "H1" keeps coming up on display
"H1" Error Code
4 Suggested Answers
SOURCE: error code F1
I had the same problem first the PRB light would come on then F! for upper then F1 for the lower and it would beep. pressing cancel cleared it for a minute then it would occure again. I pressed and held both cancels at the same time for a minute. Then went to my computer to check for solution. 1/2 hour later still no beeping.
Posted on Sep 26, 2008
  • 30 Answers
SOURCE: error code f7 on Kenmore wall oven 911.41165791
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Posted on Nov 08, 2009
SOURCE: f-7 error code on jennaire oven
My control panel died completely and I purchsed a new on. when I plugged it up I am getting an F& error code. How do I clear that?
Posted on Jan 27, 2014
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 ยท Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    I keep getting a F6E5 error code on my Whirlpool stove. I have tried unplugging it (overnight) and the error won't go away. Any ideas before I call the repair man?
    The error code F6E5 means "Cancel key error". Press the "Cancel" and "Start" keys in the following order: CANCEL, CANCEL, START. Verify the error code displayed on the control by observing for longer then 1 minute. If the error comes back then the control board needs to be replaced..
    If this was helpful please rate me Thanks
    Jun 12, 2011 | Whirlpool Ovens
    GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
    Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
    Jan 21, 2011 | GE Ovens
    When I push the bake or broil button, it displays an "F-3" code and beeps. What is the repair for this code? Thank you John
    Hi, the f-3 error code is usually for the oven temp sensor. This is the little metal rod sticking out of the back wall of the oven cavity. replace that and plug the oven back in and it should work. Hope that helps.
    Jan 12, 2011 | Kenmore 30169 Electric Single Oven
    Kenmore Elite slide in range model # C790-440732 keeps displaying error code F23 and oven will not work except on broil
    I have the same problem with my Kenmore F23 code will not bake but the broil works?? What the heck?
    Feb 07, 2010 | Kenmore Ovens
    Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
    oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
    Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
    E1 f5 error code whirlpool gr399lxhs
    The E1- F5 error is a door lock error.
    The control (TIMER) has likely failed in this instance - BUT...
    Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
    You should disconnect power again for 15 seconds and reconnect and see if that helps.
    If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
    This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
    Sometimes these work, but if the control has failed it won't make any difference.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
    Mar 25, 2008 | Whirlpool GBS307PR Electric Single Oven
    Ovens Logo
    51 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
