Question about Sony Cyber-shot DSC-W80 Digital Camera
It says "turn the power off and on again"..!!
When i turn the power on the focus comes out and goes in for 5 or 6 times and while that the display image only showing "cybershot" then when the focus stops moving the display image shows" turn the power off and on again".!!
and i cannot take any photo ,,,but i can display the old photos ...
i tried to remove the mem. stick and the same thing remained...
if anyone have any solution please....
thanx
  • 4 more comments
  • Valdinei Nov 12, 2007
    when i turn the power on the focus comes out and goes in for 5 or 6
    and on again".!!
    i tried to remove the battery and the same thing remained...
    thank you
  • narendra01 Jun 02, 2008
    "turn the power off and on again"..!! problem
    I have the same Camera and having same problem , as per my understansding all it started when I was running out of charged battery ( means battery was fully discharged and I tried to switch off the camera)...
    do we have any solution ?
    Thanks
    Narendra
  • jwaz Jun 15, 2008
    I am having the same problem too. Any solutions yet?
  • stuffdiduff Jun 22, 2008
    wow i thought i was the only one. my camera the dsc w80 is doing the same... i charged the battery and everything. Everything's working, You just can't take pictures anymore. Can heat damage the camera? Because it happened on my vacation where it was around 90 Fahrenheit.... I mean I didnt drop it or it didnt get wet or anything....
  • bahrooks Aug 14, 2008
    I'm having close to the same problem, when I go to zoom my camera, it tells me to turn it off and on again. But when I turn it back on, the problem persists.
    WARNING: if you swap memory cards or batteries with another camera, I have noticed the problem is transferred to the other person's camera, could this be a virus? (that is how the problem started with my camera, I borrowed her memory card on spring break bc her battery was dead)
  • butter14830 Dec 15, 2008
    I recently just had the same problem... the "turn power off then on again." The pulling and twisting trick worked great. Can save you alot of headache, and some money, too. Was worried I wouldn't have it for Christmas if I had to have it sent out for repairs.
  • 74 Answers
Try gently pulling and twisting the end of the lense and i mean gentle dont pull till it pops than switch it off and on again and you problem should be solved
Posted on Aug 12, 2008
Hey everyone,
Yeah, what you have to do is to kind of fool around with it like a computer. I held on to the power button for about 2min with/without the battery.
Finally, what I did was as the camera was turned off with the battery out of it. I put the battery in and turned on the power button while holding on too it for about 30 sec. It's working just fine now.
Hopefully it works for you too. Sya
Posted on Dec 17, 2008
2004 focus LR 1.8 litre zetec 5 speed manual sadan goes into limp mode while driving
What do you mean limp mode ? This only happens with automatic transmission's . Step on gas an won't go , bog's down ????? Loses power ?????
May 16, 2018 | Cars & Trucks
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
Resetting lamp life
was the button sequence given (set off) display,5, volume up, then power?
Mar 21, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
1) when i switch on my hp L1906 19" LCD monitor display comes for 2 sec. or 3 second then it goes blank. then i have to switch off and again switch on but problem remain like that... 2) in my second...
this question is posted here 100 times, search much.
the CCFL tubes are burned out
as all do ,every 20,000 hours, 5 years old if run 10yrs a day.
all do,
until 2010 when LED BACKLAMPS HIT THE STREETS
POST 101.
Also the internal power saver must be turned off.
menu button, turn it off. on OSD
Jan 26, 2018 | HP L1906 19" LCD Monitor
Dear sir My sony vaio grx570 do not turn on properly. 1-if keep it up off for one day, it does not starts booting. but after 5 to 6 tries it get power on with AC power. Windows xp logo...
When you boot the machine, use the proper key to enter the BIOS and check the date and time. If it is wrong then the BIOS battery is bad. Replace it.
Mar 03, 2017 | Sony VAIO GRX550 Notebook
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
65S500 will not turn off
Check to see if you have it set to do the Magic Focus on turn-off. It is in the menu under setup.
Nov 06, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Wont turn off, goes to magic focus
enter your menu set up and turn off auto focus and see what happens then,also check your other settings while your there.
Sep 09, 2007 | Hitachi 51F500 51" Rear Projection...
Sony Cyber-shot  DSC-W80 Digital Camera Logo
135 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
