Question about Rival MT660 Microwave Oven
Noise making while in use, the turntable makes a slight popping noise.
My microwave makes a grinding noise when running and the turntable doesn't work.
Possible there is friction within the drive , the shaft or the motor. You can remove and RESET the drive. Remove the motor , MANUALLY check the motion of the mechanism which will confirm the case. You c an reset using a bit of lubrication.
Jan 10, 2013 | Microwave Ovens
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
I purchased a panasonic nnsd797s inverter microwave in Febr 2010. The turntable appears to have been the source of noises for the past few months. It quited down for a while, but is not louder than ever...
The turntable motors cannot be lubricated, only replaced. The popping noises you mention, is that from the motor or from the microwave arcing??? Unplug the turntable motor and put a cup of water into the unit and run it for a little bit and listen, if it is stil popping you may have other issues.
Oct 06, 2017 | Panasonic NN-SD797S Microwave Oven
I have a whirlpool GH4155XPS-3 microwave. It has stopped cooking. Lights and turntable turn on but will not heat. It makes a poping noise every now and then, but not always and also makes louder noise than...
The magnetron has become defective, especially when it is followed by popping noises and is laboring are classic signs of failure. The other two components that should be checked are the high voltage capacitor and diode, but considering the repairs needed it would be cheaper to replace.
Feb 06, 2011 | Whirlpool Microwave Ovens
Microwave turntable guide
it could cause the magtron to arc...becaus the exsposed metal...you can purchase the paint for the inside color of microwave...sand around area..wipe out,,,unplug microwave first....leave door open ,spray it ,let stand couple of hours or 1 day...hope this helps...michael doctorr airr appl.repair 843-384-8474..call if need assistance..good luck
Mar 26, 2010 | GE JES1851 Microwave Oven
Turntable makes a popping noise
The problem with turntable motor or coupler which sits on turntable motor shaft.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 30, 2008 | Whirlpool MH7135XE Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Oct 17, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Rival MT660 Microwave Oven Logo
16 people viewed this question
Top Rival Microwave Ovens Experts
William Miller
William Miller
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Rival Microwave Oven Expert? Answer questions, earn points and help others
