Question about Monoprice WHDI 5GHz Wireless 1080P HD HDMI AV Transmitter & Receiver
Error message "Please Activate Registration on Transmitter Unit"
Can't get the two units talking wirelessly
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
Feb 02, 2016 | Ricoh Aficio SP C410DN Laser Printer
How do hook up the wireless unit to laptop?
There must be two items (at least) for the unit to work ... a transmitter and a receiver. The keyboard will have a transmitter internal to it. There should be a receiver unit (either a dongle or a USB cabled unit) that connects to a port on the laptop. They communicate together to wirelessly pass the keyboard data to the laptop. Without the laptop part the keyboard in just a door stop.
Dec 15, 2014 | Computers & Internet
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Why does my registration not work for my uniden surveillance system work
You may have done what I did, and I kept getting an invalid registration error. You have enter the name and registration number from the back of the unit. I was entering MY name. Don't enter YOUR name. You have to enter the name on the back of the unit, along with the reg. number.
Dec 01, 2012 | Uniden UDW10003 Wireless Portable Video...
I am getting error message ' Load Tray 1, 024-910, Printer' but there is paper inside. Once we open tray and close, error message dissapears. Regards Melane
Make sure that after you add paper, that you tell the printer the right size paper. Chances are you accidently changed the paper size and the printer is letting you know that the "wrong" paper is in the tray. If you are using standard printer paper, be sure to change the paper settings back to "Letter"
Dec 08, 2010 | Dell 5110cn Laser Printer
After installing new battery transmitter does not activate reciever. reciever still tells time etc.
You may need a new battery in the sending unit as well.
Also make sure that the wheel magnet is close enough to the sender to pick up the signal to send.
Nov 22, 2010 | Cateye Fitness Cateye Strada Wireless Bike...
My printer ricoh 3260c is not registering and when I do the auto registration the yellow is still not registering
Sounds like you have a registration problem.!
Please try the fallowing.
First, please remove all print cartridges and power of unit. (Completly disconnecting the power source).
Next, please clean with worm water and a tissue ( Q-Tips ) the cartridge area ( Print heads ).
Next, please wipe the cartridge base unit you see alittle ink on the tissue. ( again with worm water and tissue or Q-Tips. )
Now, with cartridges removed, please power on unit and wait for error messages.
Next, please install print cartridges, one at a time and see if the unit comes back.
When both are installed, the unit should see that they have been removed and will ask you to aline cartridges.
Hope this works out for you.
Please rate kindly
Happy Holiday's
John
Dec 07, 2009 | Office Equipment & Supplies
Home link system program?
  1. Turn off the engine.
  2. Erase the factory test codes by pressing buttons 1 and 3. Release the buttons when the two green lights begin to flash (about 20 seconds ).
  3. Choose one of the three buttons to train. Position the end of your hand-held transmitter 1-3 inches (5-14 cm) away from the lower left corner of the EVIC display while keeping the display in view.
  4. Simultaneously press and hold both the desired Transmitter button and the hand-held transmitter button. After a short time, the message TRAINING will show on Transmitter display. Do not release the buttons until the message TRAINED appears on the display (this may take as long as 60 seconds ), release both the Transmitter and hand-held transmitter buttons.
  5. Press and hold the just-trained Transmitter button. TRANSMIT should appear on the display. If your device activates when the Transmitter button is depressed and released, programming is complete. To train the other buttons, repeat the process. Be sure to keep your hand-held transmitter in case you need to retrain the universal transmitter. NOTE: If the message TRANSMIT appears on the Transmitter display but your device does not activate, the device may be equipped with a "rolling code" system. Continue with steps six through eight below to complete the programming of a rolling code equipped device (most commonly a garage door opener).
  6. At the garage door opener receiver (motor-head unit) in the garage, locate the "learn" or "smart" button. This can usually be found where the hanging antenna wire is attached to the motor-head unit. Firmly press and release the "learn" or "smart" button. (The name and color of the button may vary by manufacturer.) NOTE: There are 30 seconds in which to initiate the next step.
  7. Return to the vehicle and firmly press, hold for two seconds and release the programmed Transmitter button. Repeat the "press/hold/release" sequence a second time, and, depending on the brand of the garage door opener (or other rolling code equipped device), repeat this sequence a third time to complete the programming process.
  8. Transmitter should now activate your rolling code equipped device. To program the remaining two buttons, simply repeat the process.
Dec 21, 2008 | Jeep Grand Cherokee Cars & Trucks
LG wireless dvd reciever system
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Mar 21, 2008 | LG Electronics HTW316 5.1 Channel Wireless...
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Monoprice WHDI 5GHz Wireless 1080P HD HDMI AV Transmitter & Receiver Logo
65 people viewed this question
Top Monoprice Televison & Video Experts
Are you a Monoprice Televison and Video Expert? Answer questions, earn points and help others
