Question about Frigidaire Refrigerators
On my lghs2644km model refrigerator, on the control panel it says "controls are locked" so we literally cannot do anything. we can't switch to ice or change the temperature of the refrigerator. We just moved into this house yesterday and they didn't leave a manual or warranty.
SOURCE: Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Posted on Oct 13, 2008
localwonder
  • 6784 Answers
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Posted on May 25, 2009
  • 36 Answers
SOURCE: Sub Zero 680 freezer temperature problem
check the condencer on top .open the doors look up you should see three screws take them out and pull down the panel and clean the condencer if its clean CALL repair guy!
Posted on Jul 24, 2009
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
SOURCE: Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
Posted on Apr 15, 2010
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 11, 2015 | Frigidaire Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
May 03, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
My frigidaire LGHS2667KPO its control panel is not responding to the button it is stuck in ice and the temp can not be changed any ideas what is wrong with it.
Good Evening jesus, that's a great question!
From what you have described it sounds like you may have enabled the control lock on your Frigidaire refrigerator and that is why your control panel is being unresponsive. If you look on your control panel press and hold the control lock button down for three to five seconds. The light should turn off. If that does not help to correct your issue I would suggest performing a reset on your refrigerator and you can do that by flipping the household circuit breaker off for roughly ten minutes. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Feb 08, 2015 | Frigidaire Refrigerators
On my lghs2644km model refrigerator, on the control panel it says "controls are locked" so we literally cannot do anything. we can't switch to ice or change the temperature of the refrigerator. We just...
Here is where you can get a manual. Page 9 discusses lock / unlock. Just hold the control lock button for 3 seconds to toggle between the lock off & on. http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241979200en.pdf
Feb 08, 2014 | Frigidaire Refrigerators
Whrilpool side by side refrigerator control pannel does not work
Silly thought but cntrl panel could be locked. Check that the child lock is off. The bracket that holds the microswitches in the dispenser area could be broken. Wire harness at door could be disconnected. what is the model number?
Mar 11, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water/ice dispensor not working
There is usually a button on the control panel to lock the the water and ice.  Since it is both this is the most likely cause.  If your controls are not locked the the control panel is probably lacking power somewhere and will need in depth troubleshooting.
Oct 25, 2009 | Amana DRS2462B Side by Side Refrigerator
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
14 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
