Question about HP Color LaserJet 3500 Printer
Program addressograph model 610 plastic card embosser
2 Suggested Answers
SOURCE: cannot print on folded, embossed thank you cards, error code unexpected size
created a new form in the printer file with the proper dimensions. prints fine now.
Posted on May 08, 2009
How do I print card envelopes with XP-610
depends on what program you are using. If using MS works you can open envelope documents to type the address on. then print
Oct 12, 2014 | Epson Workforce 610 All-In-One InkJet...
I need for a v 610 to work thru a phone line only
VX610 can also work for phone line only, maybe try calling your credit card processor about the program settings in your machine, to set it up to dial the phone line first when doing a transaction, or maybe you need to downgrade to VX3730 or VX510 dial only unit. If you still needs help maybe we can help call (775) 358-2922 and Look for Randy
Apr 29, 2011 | VeriFone VX 610 Credit Card Terminal...
My data card 295 embosser machine i cant seem to set my format to to get the 17 number across be for i go down to the name
quickest way is to reformat the zip drive and start from scratch. im not to familiar with the 295 model embosser.
Mar 26, 2011 | Computers & Internet
How to access the battery?
hi what model honda do you have? generaly batteries on motorcycles are either behind the plastic side panels or under the riders seat theres usally a black plastic cover over the top just to make it harder to find use a torch and shine it across the covers and you will probably see the words battery or flamable embossed in the plastic cover
Feb 21, 2011 | Honda VF 750 S Motorcycles
Hi, am going to try to download my photos from an ixus 70 camera, i have found the plastic thingo on the side where i think i put the usb cable but can't open it, is there a technique with it, push pull...
I have this model. The USB socket is under a plastic flap on the side next to the shutter button. It has "AV/OUT DIGITAL" embossed on it. There is a little scoop on the camera body along the lower edge of the flap. You just stick a fingernail in that and lever the flap open.
However, I never use this socket myself, finding it easier to just take out the memory card and put it into a card reader on the computer (there is a reader built in to my printer).
Jan 25, 2011 | Canon IXUS V2 Digital Camera
Cannot use die cuts
No I don't think your machine is defective. Here are some "sandwich" ideas to help you. I know you asked just for Cuttlebug dies; I included other "sandwiches" that you can do with your Cuttlebug. If you need further assistance feel free to contact me.
Cardstock
Chipboard
Magnetic/ Metal Sheets & Thin cork (Media)
Cuttlebug Dies
Plate “A”, Plate “B”, Die (cutting side up), Cardstock, Plate “B”
Plate “A”, Plate “B”, Die (cutting side up), Chipboard, Plate “B”
Plate “A”, Plate “B”, die (cutting side up), Media, Plate “B”
Cuttlebug Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”
Plate “A”, Plate “B”, Folder (with chipboard inside), Plate “B”
Plate “A”, Plate “B”, Folder (with metal sheet inside), Plate “B”
Nestabilities
You will need Spellbinders Tan Embossing Mat to emboss in
Cuttlebug™ machine (or a plumbers gasket cut to size, or some use a mouse pad)
Cutting Sandwich - (Stack from bottom up)
1. A plate
2. C plate
3. Spellbinders Die (cutting side up) that means the side with the
ridges
4. paper or cardstock
5. B plate
6. Run through Cuttlebug™ machine.
Embossing Sandwich- (Stack from bottom up)
*Remove C Plate for embossing sandwich
1. Place A plate on bottom
2. Leave die face up on A plate with die cut still in the die.
3. Place one Spellbinders Tan Embossing Mat on top of the die.
4. Use 2 or 3 pieces of cardstock to shim.
*Cautionary Note: Using more than 3 pieces of cardstock to
shim Cuttlebug Embossing sandwich will result in B Plate
breakage. When using Spellbinders Edgeabilities card making
dies, shim with only 2 pieces of card stock.
5. Place two acrylic B plates on top of sandwich and run thru
Cuttlebug machine to emboss Spellbinders die cuts.
6. Turn die over and use like a stencil with inks and chalks for
added detail.
BigShot Embossing Folders
Plate “A”, Plate “B”, Folder (with cardstock inside), Plate “B”, Cardstock shim
BigShot Large Dies
Plate “B”, Cardstock, Die (cutting side down), Plate “B”
Revolution Dies
Plate “A”, Plate “C”, Die, Cardstock, Plate “B”
Sizzlit Dies
Note: Provocraft suggests using Plate” C” instead of the second Plate “B”, however, CB owners have cracked plates, so try with two “B” plates first.
Sizzix Original Dies & other Steel Rule Dies
Plate “B”, Chipboard, Die (cutting side down), Plate “B”
Sizzix CutNFold Dies
Plate “A”, Die, Cardstock, Plate “B”, Chipboard shim
Also try:
Plate “B”, Cardstock, Die, Chipboard shim (maybe 6 layers)
Sizzix Embossing Folders aka Simple Impressions
Also try:
Plate “A”, Chipboard shims, Folder (with cardstock inside), Plate “B”
QuicKuts Dies (Regular)
Plate “A”, Plate “B”, Die, Cardstock, Plate “C”
Plate “A”, Plate “C”, Die (cutting side up), Chipboard, Cardstock shim, Plate “B”
QuicKuts Dies (Grand)
Brass Embossing Stencils
Plate “A”, Plate “B”, , Brass stencil ,paper/cardstock,mouse pad (cut to size, rubber side down), Plate “B”
Sandwich may need to pass through several times based on cardstock thickness
Or use plumber’s black rubber plus red rubber gasket, instead of mouse, then add last plate B.
Big Impressions Texture Plates
Plate “A”, BI texture Plate, Cardstock, Silicone Rubber pad (from BISK), Impressions Pad (from BISK)
*BISK-Big Impressions Starter Kit
Fiskars Texture Plates
Plate “A”, Fiskars texture Plate, Cardstock, tan Wizard pad, black or tan Wizard pad, (possible Cardstock shim,) Plate “B”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (lightly misted with water), 2 layers Fun Foam, Chipboard Shim, Plate “C”
Also try:
Plate “A”, Fiskars texture Plate, Cardstock (right side towards TP), Rubber Plate (made from Plumber’s rubber gasket), Plate “C”
Plastic thin stencils
Here too- may try
Plate “A”, Plate “B”, , plastic stencil, cardstock, black rubber, red rubber, plate B
Jan 28, 2010 | Provo Craft Cricut Disney Font Cartridge
My Lumix DMC-FS3 screen says the memory card is locked. How can I unlock it?
Take out your memory card and look on the side.
There will be a little "switch" on the side. There shold be a little lock logo embossed on the plastic and your slider switch is switched to locked. Slide it in the opposite direction and you are good to go!
Cheers!
Dec 30, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Need free software for Datacard 275 Embosser
Hello
Thank you for using
FixYa for your problem
This link is for the driver or are you after software to make the datacard
http://www.datacard.com/plastic-card-embosser-drivers/275-embosser
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 20, 2009 | Office Equipment & Supplies
HP Color LaserJet 3500 Printer Logo
49 people viewed this question
Ben Johnson
