Question about HP Computers & Internet
Smart restore - HP Computers & Internet
Please can you please send me the codes to restart and restore the original make of my Vodafone smart kicka
Do the following to reset your VF68S Smart Kicka in case you ever loose of forget your screen-lock (like pattern,
password or PIN) or if the user data or cache gets corrupt so as to hinder proper boot.
1. Turn off the Vodafone Smart Kicka (VF685)
2. Press and hold both Volume Up and the Power button until the Android System Recovery menu appears
3. Scroll to Wipe data! factory restore (scroll with Volume Down/Up)
4. Select with the Power button
5. Scroll to Yes- delete all user data
6. Con?rm with the power button
7. Wait until you see Wiping complete
8. Select Reboot now and con?rm with the Power button.
You should be done after all that!
May 27, 2016 | Vodafone Cell Phones
Whenever i put on my hp mini,it says smart disk error. whenever i try restoring back to factory settings, it freezes up when it gets to 2 percent. after waiting a while it says the system fails to restore,...
Smart Disk Error has something to do with the Hard drive of your computer. I think the reason it's showing the message is that your Hard drive is about to fail. If restoring it to factory settings freezes on the same point every time chances are that part of the hard where the data is stored is busted (unreadable) better do what it says to contact hp so that they can conduct hardware diagnostics on your hard drive. Better yet, have it replaced if it's still under warranty.
Hope this helps!
May 19, 2011 | Computers & Internet
Hi, I bought Smart Epad 7" I had error of The
You can restore your epad to factory settings by going to the settings menu > privacy > Factory data reset. and then your epad should be running normally again.
Mar 04, 2011 | Tablets & eReaders
P212 not detected in post
enable HP Dynamic Smart Array in the BIOS
Dec 30, 2010 | HP P212/256 SMART ARRAY CONTROLLER Storage...
My smart phone has a white screen with a black square with hands going round phone does not work cant do any thing with it
Sounds like you need a firmware restore. Go to your provider, they might do it for you. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is How to restore Blackberry
May 13, 2010 | RIM BlackBerry Curve 8520 Smartphone
My smart restore wont work
I know such restore fails so you needs to re-format all system and then it will start working.
With Regards,
Ankit
Oct 02, 2009 | Computers & Internet
Reset factory default HP Mini 1035NR PC Notebook
SMART measures physical attributes of the hard drive. Reformatting won't help that. A bad SMART status alone doesn't mean your drive is failing, but combined with the delayed writing failures and the slow speed, I'd replace it ASAP.
May 10, 2009 | HP Mini 1035NR Notebook
Computers & Internet Logo
11 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
