Question about GE GTDP490EDWS Electric Dryers
Scraping noise Scraping sound when running
  • 105 Answers
SOURCE: Grinding, scraping noise when drying
Glides or roller replacement, could also be something from a pocket wedge between drum or cabinet.
Posted on Feb 04, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
Posted on May 22, 2009
  • 24 Answers
SOURCE: My GE Profile DPSE810 Electic Dryer has started
Depends on what kind of noise...
-Repetative muffled creaking: Probably the metal drum sliding against the plastic mount that holds the front of the drum. It can be TEMPORARILY eliminated by disassembling the dryer and tampering with the felt strip so that the drum has more play and turns more freely. It does not indicate a major problem.
-Metal against metal scraping: Maybe the metal cabinet got bashed in just enough that the drum rubs against it? This kind of sound should be investigated and fixed.
(For what it's worth, my DPSE810EG4 does has the repetative muffled creaking.)
Posted on Dec 26, 2009
ftw1952
  • 10319 Answers
SOURCE: Dryer is making scraping noise as the drum turns,
tHE FRONT SECTION OF THE DRUM LAYS INTO A SEAL THAT NEEDS REPLACING. yOURS HAS A FOLD IN IT THAT HAS WEAR CAUSING YOUR PROBLEM
Posted on May 01, 2010
heatman101
  • 43501 Answers
SOURCE: GE DPSR483EA Electric Dryer was making a scraping
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 15, 2010
2006 pt cruiser making scraping noise when wheel turning to the right
is it a scraping noise or a clicking noise. a scraping noise could indicate a brake noise when turning have the brakes checked in the front. if its a clicking noise only when turning to the right then you may have a bad cv joint on the right half shaft. replace the half shaft assembly.
Jul 24, 2014 | 2006 Chrysler PT Cruiser
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
The belt is making a scraping noise when you walk on it. i see nothing touching the belt proform crosswalk 375e
Unplug the treadmill then loosen the running belt and physically feel the full length of the deck and then chick the entire running belt something is stuck causing the scrapping.
May 15, 2010 | Exercise & Fitness
Grinding scraping noise and metal strips in the dryer.
yeah id prob just go buy a new drier, cause that one sounds as though its dried its last piece of clothing
May 05, 2009 | Dryers
93 Grand Caravan right rear wheel/brake problem(s)
well i can help with problem #2
even if you tightened the wheel bearing, it is probably worn out..
what it does when it's loose is you won't hear much noise when you drive on a strait road but the minute you put some weight on it, like when you take a curve, the weight of the body is applied on the bearing resulting in a scraping noise....
and the faster you'll drive the more noise you'll get
so let's say you take a left turn you're gonna hear noise from the right wheel...
Apr 29, 2009 | 1993 Dodge Grand Caravan
Scraping noise from dryer
probably one or both the rollers in back of drum are no good these rollers are near the motor
Apr 18, 2009 | Maytag Dryers
Feb 01, 2009 | GE DBSR453EBWW Electric Dryer
Right rear is making a sound of medal scraping medal. I believe it maybe the wheel bearings.
If it's a scraping sound, when does it happen? If it's when you hit the brakes, then it's likely your rear brake pads/shoes are down to the metal and are scraping. This can happen when you're not hitting the brakes, however. Bad wheel bearings are usually a moaning/roaring sound that increases as road speed increases. Ditto that for differential bearings - if they go out, you usually get a roaring noise that increases the faster you go.
Aug 10, 2008 | Ford Explorer Cars & Trucks
Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Jun 01, 2007 | Creda W100FW Front Load Washer
GE GTDP490EDWS Electric Dryers Logo
18 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
